Cylinder misfire problem...... please help!
Old Oct 22, 2007 | 09:00 AM
Febus's Avatar
Default Cylinder misfire problem...... please help!
Hello everyone, I recently purchased a 1996 850 GLT Wagon. It runs great except when I'm stopped at a light she has a shake, when my son plugged the computer in it said it has a misfire on cylinder 2 and 4, I put in new plugs, wires, cap and rotor, as well as fuel injector cleaner, when we checked again it said that cylinder 2 is misfiring, but it no longer shows cylinder 4. Where else should I check? I would really appreciate any help on this issue since this is my daily driver and I don't want to do anymore damage. Thank you, Nelson.
Old Oct 22, 2007 | 04:40 PM
axelm's Avatar
Default RE: Cylinder misfire problem...... please help!
Plugs, wires, cap and rotorshould have solved it. How about a compression test on cyl#2?
Old Oct 22, 2007 | 05:57 PM
Do a compression test on all the cylinders.
Old Oct 22, 2007 | 09:55 PM
Febus's Avatar
Thank you, I will have a compression test done and post my results, Nelson.
Old Oct 23, 2007 | 08:58 AM
JimKW's Avatar
Make sure you do a wet test on the cylinders that have low compression to see if the problem is in the head or with the pistons.
Old Oct 24, 2007 | 07:47 AM
axelm's Avatar
I imagine you have already triple checked that the spark plug wire boot is correctly seated on cyl #2, and that the spark plug is correctly installed. Bad threads would make the spark plug be positioned incorrectly.
Old Oct 25, 2007 | 01:24 PM
Febus's Avatar
Thank you all for your help, I haven't had much time to look at it with work and all, but I will check it all this weekend, Nelson.
Old Oct 31, 2007 | 07:37 AM
axelm's Avatar
Any news on this problem?
dlaxdal
Aug 12, 2011 07:44 PM
akirk6884
Dec 24, 2010 10:29 PM
joseangel
Jun 5, 2009 11:18 PM
porlagran
May 13, 2009 09:31 PM
