Dash light do not come on.
Old Sep 26, 2007 | 12:48 PM
tcoxey's Avatar
Default Dash light do not come on.
I have an 1995 850 Wagon, when I turn on the headlight switch the headlights come on but not the dash lights. Could this be a bad headlight switch or some other problem. I have just changed theignition switch recently.
Old Sep 26, 2007 | 01:02 PM
99VolvoV70's Avatar
Default RE: Dash light do not come on.
I actually have the same problem. For awhile I could hit the bottom of the switch and they'd click on. Last night it got to the point of having to keep pushing on the switch, so I got underneath and checked it out. I couldn't see very well from the foot compartment (after removing the plastic panel from under the steering wheel), but I felt around and found the electrical connections at the back of the switch. I pushed and probed around until the lights came on. In the end, I couldn't find anything loose, so I just pushed on the bottom of the switch from behind it. The bottom of the switch is popped out a little bit now, but the lights are actually working. I figure it'll stay like that for awhile and eventually get pushed back in and I'll have to push it out again.
Not a permanent solution but it worked for me.
Old Sep 26, 2007 | 08:25 PM
white out's Avatar
What is the dimmer set at?
Check the fuse.
Nick
Old Sep 27, 2007 | 08:33 AM
Psaboic's Avatar
+1 to White Out. If checking the fuse and dimmer switch doesn't work, I would pop out the dimmer switch and the headlight switch and check the connections.
Glenn
Old Sep 28, 2007 | 05:56 PM
The headlight switches are also known to come apart.
That allows the headlights to be on but not the dash lights.
Push in on the headlight switch and see if they come on.
Old Sep 28, 2007 | 09:42 PM
JPN's Avatar
JPN
And if you can, take the switch out while the ignition switch is OFF, and spray clean the connections with electrical contact cleaner and reconnect to see if it cures the problem (this is pretty much the same advice as Glenn's).
The switch pops out as you insert a small flat-blade screwdriver in the tiny gap, no brutal force is required as it is held in place by spring tension. While you're at it, inspect for any damage. If cleaning doesn't solve the problem, there may be a loose connector for the instrument panel back light. You can access the instrument cluster assembly via:
http://www.fcpgroton.com/volvo850gearinstructions.htm
Good luck,
JPN
97black850
Oct 2, 2013 09:44 PM
Danigirl
Feb 22, 2012 01:36 PM
tcr75
Mar 19, 2010 04:58 PM
macbeth998
Feb 5, 2010 07:02 PM
