Dash lights replacement & Odometer
1995 850 GLT, approx 115,000 miles.
Need to replace some lights in the dash/instrument panel and also fix the odometer (broken). I was going to order the Odometer kit from http://ipdusa.com/ProductsCat.aspx?C...357&RootID=629 and wanted to order the light bulbs to replace all of them at the same time so that I good for a long time. I need your recommendation of where I could buy all the bulbs as a kit and also your input on doing both jobs at the same time. Regards |
RE: Dash lights replacement & Odometer
You can buy the gears here as well.
http://www.odometergears.com/subpages/volvo.html 4 out of the 5 or 6 bulbs you need you can buy anywhere they are just the small pushin bulbs. The clock ones are Dealer ones. The job isn't all that bad. I made a sticky about removing the cluster. |
Tech and everyone at this forum,
Thank you for your help and support. I finally found the time to fix the odometer, it works great. The IPD kit with the DVD made it a very easy job as I did not have to think. Wishing you all a happy new year (a few days ahead) |
