Dash lights replacement & Odometer
Old Oct 1, 2006 | 12:43 PM
guptash's Avatar
Default Dash lights replacement & Odometer
1995 850 GLT, approx 115,000 miles.
Need to replace some lights in the dash/instrument panel and also fix the odometer (broken).
I was going to order the Odometer kit from http://ipdusa.com/ProductsCat.aspx?C...357&RootID=629
and wanted to order the light bulbs to replace all of them at the same time so that I good for a long time.
I need your recommendation of where I could buy all the bulbs as a kit and also your input on doing both jobs at the same time.
Regards
Old Oct 1, 2006 | 09:54 PM
Default RE: Dash lights replacement & Odometer
You can buy the gears here as well.
http://www.odometergears.com/subpages/volvo.html
4 out of the 5 or 6 bulbs you need you can buy anywhere they are just the small pushin bulbs.
The clock ones are Dealer ones.
The job isn't all that bad.
I made a sticky about removing the cluster.
Old Dec 24, 2006 | 11:21 AM
guptash's Avatar
Tech and everyone at this forum,
Thank you for your help and support.
I finally found the time to fix the odometer, it works great. The IPD kit with the DVD made it a very easy job as I did not have to think.
Wishing you all a happy new year (a few days ahead)
Ratphink120
Mar 11, 2022 10:41 AM
mikwik
Oct 22, 2011 05:42 PM
labelsdc
Apr 15, 2011 08:57 AM
850GLE
Sep 22, 2009 10:28 AM
quarterdimenickel
Jul 16, 2008 07:52 AM
