does this have a valve gasket in it?
Old Apr 10, 2006 | 09:46 PM
cool_kyle_3000's Avatar
Default does this have a valve gasket in it?
http://cgi.ebay.com/ebaymotors/NEW-V...spagenameZWDVW
I was wondering if this has a valve gasket in it because oil is leasing out of my car at that point. THX
Old Apr 11, 2006 | 10:22 AM
JimKW's Avatar
Default RE: does this have a valve gasket in it?
They don't have a Valve Cover gasket. When you take the cam cover off to expose the cams and the valves you have to get a sealant from Vovlo and put it on with a paint roller, then put you cam cover back on. It's a real pain in the ??? in my opinion. You never know exactly how much to put on. I've heard you should not use anything other than the Volvo sealant, and it's about $30 a tube.
Old Apr 11, 2006 | 10:41 PM
Correct only the Volvo sealer works good.
Where exactly is it leaking from?
Old Apr 11, 2006 | 11:46 PM
here is where it is leaking.
[IMG]local://upfiles/3376/BE9B90DB4AF245EA97509387DB7224F9.jpg[/IMG]
[IMG]local://upfiles/3376/9DA1B2A6E99643889F632BA5049F5FA8.jpg[/IMG]
[IMG]local://upfiles/3376/D1E961ADB1C94BA7B4D498DBD7F7579A.jpg[/IMG]
Old Apr 12, 2006 | 12:10 AM
Have you checked under the cover to make sure it isn't from the oil cap seal leaking?
You might have a clogged Vent box causing it to push oil out the Cap.
Old Apr 12, 2006 | 05:51 PM
hey i just want to say thanks for all your help with my car and getting it back to perfect shape. I havent done that yet but i think that i am. Hopefully it is just a clogged vent and needs to be cleaned out. After i do that ill let ya know whats up. plus more pictures.
P.S: How long would you say it would take?
Old Apr 12, 2006 | 10:12 PM
If you remove/replace the Vent box it will take you a while you have to remove the intake to get to it.
Old Apr 12, 2006 | 10:26 PM
JimKW's Avatar
If you take the intake off, the bottom bolt holes on the intake have slots in them so you don't have to take the bolts out all the way. That makes if much easier to put back on. Otherwise lining up the gasets would be real tough.
Old Apr 13, 2006 | 11:29 PM
is there any products i can buy to help?
GrantRobertson
Jul 2, 2013 01:49 AM
ycartf
Jun 28, 2010 08:28 PM
almatic
Jun 6, 2010 01:53 PM
HummerGuy
Aug 21, 2008 09:13 PM
matthewensey
Aug 21, 2005 02:40 PM
