Drivers side Wiper Arm lifts off the last 1/4 stroke
Old 01-17-2009 | 12:54 PM
Adrenalin540's Avatar
Default Drivers side Wiper Arm lifts off the last 1/4 stroke
Anyone have the fix? I thought I had it but evidentally not!
Thanks
Old 01-17-2009 | 01:20 PM
Default RE: Drivers side Wiper Arm lifts off the last 1/4 stroke
I remove the arm and use a bench vise. I slide the arm in the vise with a rag and GENTLY push it in a little and bend it slightly towards the way it would sit closer to the windshield.
Old 01-17-2009 | 01:50 PM
Thanks Tech...I will give it a go. Man I am in BMW forums that are good and they have a lot of good members - but as a moderator you make this forum one of the best! Thanks a million.
Jim
Old 01-17-2009 | 01:57 PM
Deeter's Avatar
I had the same problem with my car. I was able to fix the arm without removing. See the link below.
http://volvospeed.com/wiperarm.php
Old 01-17-2009 | 02:01 PM
ORIGINAL: Adrenalin540
Jim
Thanks I try the best I can to help others!!!
Old 01-17-2009 | 08:55 PM
JPN's Avatar
JPN
I cut a 1mm (0.0394") thick washer in half and installed it beneath the arm pivot, so that the arm was installed at an angle and the problem solved. Just an alternative.
JPN
Old 01-18-2009 | 06:14 AM
JimKW's Avatar
I did just what Tech said. It took very little bending. It's very easy to take off. I was not sure I even bent it at all, but figured if it was not enough it was easy enough to do a little more. It was find and I never had to take it off again.
Old 01-19-2009 | 12:30 AM
jikispqr's Avatar
I did it in a different way (actually technician who I took the car to), maybe to rough but, unfortunately i thought this was only me who had this problem - this guy from the Opel Center, he just bend the arm somewhere in the middle, it is not bothering me as a driver, but it definitely is not good looking.
what, if the old arm which lifts off will be changed with a new one, will it have the same problem?
thanks
Old 01-19-2009 | 09:01 AM
If you put a new one on it will sit right and look alot better.
Old 01-19-2009 | 09:08 AM
Psaboic's Avatar
Strange, but our volvos are the only car I have ever owned that has this issue with the wiper arm. Wonder why?
Old 01-20-2009 | 12:55 AM
jikispqr's Avatar
really strange.
thanks Adrenalin540 for putting this question
Old 01-20-2009 | 09:33 AM
95volvo850's Avatar
Strange issue that mine had as well. I bent the arm while still attached as suggested by Deeter. Worked great. You guys are the best.
Thanks
Old 01-20-2009 | 04:18 PM
axelm's Avatar
ORIGINAL: 95volvo850
Thanks
+1 Thanks guys. I had the same problem and it has been bugging me for a long time. Fixed it in 30 seconds.
Old 02-06-2009 | 01:48 PM
chibar78's Avatar
Hi eveyone, i don't know if this is the right forms to ask, i have a 1993 Volvo 850 GLT, the driver side windshield wiper is not working, the passanger side is fine, can anyone tell me if the windshield motor is bad (how to check it)or just need to change the arm. thank you so very much.
sam
Old 02-06-2009 | 03:25 PM
jspaulding46947's Avatar
I'm definitely glad to hear I'm not the only one!!! I made it a little better a while ago but was afraid to push down on the arm more than I did, tomorrow I'll have to push on it a little more and see if I can finish the job Thank you all for this good information!
Old 02-06-2009 | 07:21 PM
JimKW's Avatar
sam
Before assuming the motor is bad try just tightening the nut that holds the wiper arm on. I have had this happed to me where the nut just gets lose. If the shaft to the wiper arm does not move with the wipers on, the motor is bad.
  #17
Old 02-06-2009 | 09:48 PM
Bruce Wayne's Avatar
this fixed mine as well! thanks
  #18
Old 02-06-2009 | 10:23 PM
mcleantmw's Avatar
Thanks
My daughter's 1995 Volvo 850 GLE also had the same problem with both wiper arms. First I put on heavy duty winter wiper blades that are thicker and higher blade size (bought them at Costco) which allowed more pressure on the wiper arm and blade. That worked the first year but then when it was time to replace the blades, I couldn't get the real heavy duty winter blades, I had a real problem with the wiping on the windshield. I tried tightening the nuts on both arms and that helped a little but still was a problem. So, I took both arms off, and not having a vise like others used, I just bent the wiper arms over the edge of a concreate step. They work like champs now even though they do stick up a little. I think the main problem where the wiper arm connects by the nut by the hood........the base isn't as solid anymore from the continual use and just wear and tear of the vehicle. Just thought I'd also share my little tricks to improve the wiping..........the heavy duty winter type wipers might solve the problem for some; bending the arms for others; and then maybe new wiper arms for others.
  #19
Old 02-09-2009 | 02:40 PM
chibar78's Avatar
thank you so much everyone, i will try it later.
  #20
Old 02-11-2009 | 04:49 AM
Trillogy's Avatar
Mine had this problem, but it's a very easy fix. Just bend the small part of the wiper arm toward the windshield. Don't over do it, it only takes a little. This works fine and you don't see the bend, if you keep it small.
