DTCs 4-3-5 and 4-4-3
Hi All,
Looking for collective knowledge/experiences on this one. Here's the story:
1995 850 20Valve N/A; approx 160K miles
A few weeks ago i get a CEL; DTC is 1-5-3 which is "Rear HO2S Signal". So I replaced the rear Heated O2 sensor; OEM Bosch from IPD. But note: when i took the old sensor out, I noticed a couple of the sensor wires had worn through the insulation, up near the connector, from rubbing on the frame/chassis (not routed correctly). I considered just repairing the insulation and reusing it, but I had already bought the new O2 sensor and figured it was probably due anyway so I went ahead and put the new one in.
Within a couple of days the CEL comes on again; this time it's two codes:
4-3-5: Front HO2S Slow Response
4-4-3: Three Way Cat Converter Efficiency
So has anyone experienced this before? I almost tempted to put the old rear sensor back (repair the insulation) in and see what i get.
Yeah, it's possible i need both O2 sensors and a new CatConverter at this mileage; just seems a bit strange all this happened at once.
BTW: For more detailed info on what these codes mean, found this great post:
http://www.volvoforums.org.uk/showthread.php?t=8600
Appreciate any input/suggestions.
Also any experience with replacement CatConverters? FCP sells this one for $250; MFG is Davico; anybody know if this is OEM?
Thanks again!
Thanks again!
Thanks for the input tech; looks like another O2 sensor is in my future...
I would still appreciate any experiences/knowledge regarding the cat converters though...
- Does cat generally need to be replaced after so many miles, or do you wait until you see symptoms or codes that point to the cat being bad first?
- Do cat converter usually get more restrictive (flow wise) with age/mileage, or less?
- Any feedback regarding aftermarket cat converters?
