Engine Ground Cable?
RE: Engine Ground Cable?
Not sure about your wording... Are you saying that you have disconnected the ground or something? In any event, either the battery is properly grounded or it is not. It would not be making its own new path. There could be a new path if there is a short somewhere. But to start, maybe back up and start with what year car, mileage, what's been going on with it to bring you here. If you have the OBD1 set up, read the codes and post back. If you have OBD 2, go and get the codes read. Post them and then we can try to point you in a direction....
