Exhaust
Old Mar 28, 2005 | 11:17 AM
Bouncer_Vang's Avatar
Default Exhaust
I have a 96 850 GLT I have many questions about my 850...For some reason my exhaust is rather loud...and the check engine is always being lit up...Does these two have any significance together...I really don't mind about the exhaust noise...To be truthful I like it a lot..It's just my dad that's not so fond of it and Both me and my dad don't like seeing the "check engine" light up....It gets us worried that the car might die without notice...I've had my dad take it to some shops and get numerous things fixed...we've spent over about 400 fixing the car...Any help is appreciated....THanks
Old Mar 28, 2005 | 12:39 PM
Patrick's Avatar
Default RE: Exhaust
check engine lights are designed specifically to pertain to emission related issues...if you have a problem with your catalytic convertor, or a pipe around it, it could cause the CEL and the noise...any exhaust shop should be able to diagnose the issue.
Old Mar 28, 2005 | 01:18 PM
Default RE: Exhaust
If the shop does diagnose the exhaust how much do you think it will cost to replace those parts??? I just wanted to know out of curiosity
Old Mar 28, 2005 | 02:24 PM
JimKW's Avatar
Default RE: Exhaust
I have a 94 850 Turbo with 203,000 miles and never changed anything on the exhaust. It's kind of loud, but not that bad. I have had it checked recently and they tell me everything is fine. My CEL is on all the time. I just started ignoring it. I got tired of paying to replace sensors when there was nothing wrong with the car other than a bad sensor. I bought the car practically new (9,800 miles) and the light has been on more than off. I wish I knew how to turn it off. I tried just diconnecting the battery, but it did not go out and then I had to put the code in to get the stereo to work, reprogram all the radio buttons and reset the clock. And the light did not go out.
Old Mar 28, 2005 | 03:00 PM
Default RE: Exhaust
The light can come on from the gas cap loose to a pin hole in a vaccum line.It could be about 100 diffrent things that turn the light on.If you can get the codes pulled and let me know I will try to help you through it.
The 850 Exhaust is normally pretty loud.
Old Mar 28, 2005 | 03:01 PM
Default RE: Exhaust
Okay....ummm so is it okay to just ignore it??? It's not that big of a problem is it??? because if it's not then i'll just leave it...
Old Mar 28, 2005 | 03:09 PM
Default RE: Exhaust
Well you could have a bad O2 sensor and it will run way to rich and also cost you tons more in gas.
Old Mar 28, 2005 | 03:21 PM
Default RE: Exhaust
maybe that is the problem...My dad has been complaining about the gas...But he says that it's because it's a 5 cyl (^_^)
[IMG]local://upfiles/1732/9124E5C061774D0AA82A48BFC72A9168.jpg[/IMG]
Old Mar 28, 2005 | 03:31 PM
shotti1's Avatar
Default RE: Exhaust
Yo Bouncer,
I've got a 850 and made the mistake of replacing both o2 sensors after having pulled the code. 9 times out of 10 it's not the sensors, but a small vacuum hose below the left front (facing the car) side of the intake manifold. It's a couple dollar part (little 90 degree elbow) and a hour or two to replace it. It's very hard to see. Check out Bay 13, I'm pretty sure there's a write up about it there. Good luck.
Old Apr 3, 2005 | 01:35 PM
Turbovolv85023's Avatar
Default RE: Exhaust
how do i get mine loud like that, its pretty quiet
Old Apr 3, 2005 | 01:58 PM
Default RE: Exhaust
You can have a performance muffler installed.
Old Apr 3, 2005 | 03:31 PM
knight rider's Avatar
Default RE: Exhaust
You can also get the resonator removed and replaced with 2 1/4 straight pipe. I did that with my lexus gs400 and it was awesome sounding. Wanted to do it to my volvo, but tryin to sell it so....
turbowagon94850305
Jul 31, 2010 10:48 PM
Fluxmotoring
Nov 18, 2008 02:53 PM
knight rider
Jun 26, 2005 09:10 PM
volvobacon
Apr 16, 2005 11:34 AM
DrewG1998
Sep 15, 2004 10:09 PM
