Failed Smog So. Calif
Need Help...
I just failed smog on my 95 850 wagon great car, I did not pass Nox at low speed, Prior to the test I removed and cleaned my egr. when the guy told me I failed he gave me a couple of tips to check the operation of my egr, since I have determine the my vacuum controller is not allowing vacuum to the egr. can someone tell me how I can check the operation of this device? and also how it should work?
many thanks to all who support us weekend warriors..
Jesse
Jesse
A vacuum/pressure hand pump can tell you if the valve is working. Whether is seats or not is another Q. You'll need to take it off.
A trick I learned last year with passing smog. If your car is failing due to emissions run your tank down to about 2 gallons then go to Home Depot and buy a gallong of Denatured Alcohol and pore it in your tank. Got get your smog test...pass, run it close to empty then fill your tank up full. Sounds odd but I ran across this because I was not passing smog on my Chevy. It was my last straw. I did it and passed, the emissions were so clean it made me laugh when I saw the numbers. I am in California too.
Need Help...
Jesse
Jesse
