Fan belt question
Old Mar 14, 2007 | 09:53 PM
Riculus's Avatar
Default Fan belt question
Whats up Guys,
I have to replace my fan belt. I would like to know if I have to buy the OEM or I can get an aftermaket one.
Another thing, my oil light stays on for about a second when I start the car, is this normal or is it something I should look into immediately.
Thanks for the help
Riculus
Old Mar 14, 2007 | 10:51 PM
JimKW's Avatar
Default RE: Fan belt question
I bought the OEM belt, but not sure it's necessary. There are two different size belts and either will fit, but you need to route them differently. Just something to watch out for. My oil light stays on for about a second also on the 97 850 R. I don't think it's anything to worry about, but somebody might tell us differently.
Old Mar 15, 2007 | 01:33 AM
JPN's Avatar
JPN
Hi Riculus,
Greetings from Yokohama.
As for the accessory drive belt, I would definitely go with OEM (Continental Tech). Other brands' belts are noted for squeal. Also, I would go with the longer belt, it gives you more contact with the alternator pulley, and Volvos are highly sensitive to power requirements.
As for the oil lamp, some cars seem to stay on longer. If it bothers you and if your 850 is non-turbo, try switching to 5W-30. But I believe it's nothing to be concerned of.
Good luck,
JPN
Old Mar 15, 2007 | 11:37 PM
Riculus's Avatar
Thanks JPN and JinKW for the replys guys. I truely appreciate your comments.
Riculus
ingydrummer
Feb 28, 2020 03:33 PM
norasaint
Sep 20, 2012 12:53 AM
Marks 240
Oct 26, 2011 11:56 PM
elouadj
Jun 25, 2008 07:00 PM
vcolper
Nov 1, 2006 10:20 PM
