Fender rolling time
The most important part is HEAT..
Use a heat gun to keep the paint flexible and it wont flake or crack..
But be careful to much heat and you could blister the clear..
Here is the fender roller I bought, It has since grew legs and walked away but its awesome, it makes the job sooooooo easy.
Eastwood Fender Roller | Fender Roller Tool | Auto Fender
Twiin: running a 225/45/17. I rub when i hit bumps (the outer edge of the tire hits the fender inner liner and metal fender) and rub the inside edges a little bit when i turn. I think 5 mm spacers will fix that, but not until the fenders are rolled.
MadMtt: Running H&R springs. drop is supposed to be about 1.6"
Do you have spacers on there, too?
Anyone who is at stock offsets with lowering springs doesn't need to roll their fenders.
Like Matt said, tons of heat and take your time. I did it on both my fronts and rears.
I rub like mad on the rear when I have passengers back there. No spacers in the front at all but i still scrub whenever I hit a bump, gilber. I suspect it has more to do with the width tire im running than offset. If I wasnt running the 15mm offset in the rear, I think the tire would be hitting the inner fender pretty bad.
Also, I scrub the front pretty bad when I turn the wheel all the way to lock. I think a 5 mm spacer in the front would go a long way towards fixing that, once i rolled the fenders.
