Fender rolling time
Old Jul 24, 2012 | 11:07 AM
ibified's Avatar
Default Fender rolling time
Yep....gonna have to roll the fenders on my car. Since I got the new springs on, in combinsation with the 225/45/17 tires, I'm definitely rubbing. Love the look though.
Anyone have one? anyone done it? Anything I need to be careful of?
Old Jul 24, 2012 | 01:55 PM
Msuperbauer's Avatar
I hear that its very important to go very slow so the paint doesnt flake off. although it still may, your chances are less if you do a little bit (very slowly) wait a day or 2, then repeat.
Old Jul 24, 2012 | 05:41 PM
twiin64's Avatar
What part rubs with those tires? I've got a set of Volans and I'm presently shopping for tires.
Thanks in advance.
Old Jul 24, 2012 | 06:05 PM
Mad Matt's Avatar
What springs are you on?
Old Jul 24, 2012 | 06:45 PM
MattyXXL's Avatar
The most important part is HEAT..
Use a heat gun to keep the paint flexible and it wont flake or crack..
But be careful to much heat and you could blister the clear..
Here is the fender roller I bought, It has since grew legs and walked away but its awesome, it makes the job sooooooo easy.
Eastwood Fender Roller | Fender Roller Tool | Auto Fender
Old Jul 24, 2012 | 07:34 PM
ibified's Avatar
Twiin: running a 225/45/17. I rub when i hit bumps (the outer edge of the tire hits the fender inner liner and metal fender) and rub the inside edges a little bit when i turn. I think 5 mm spacers will fix that, but not until the fenders are rolled.
MadMtt: Running H&R springs. drop is supposed to be about 1.6"
Old Jul 24, 2012 | 10:42 PM
Do you rub in the rear at all or only in the front ??
Old Jul 25, 2012 | 01:18 PM
gilber33's Avatar
Do you have spacers on there, too?
Anyone who is at stock offsets with lowering springs doesn't need to roll their fenders.
Like Matt said, tons of heat and take your time. I did it on both my fronts and rears.
Old Jul 25, 2012 | 02:52 PM
ibified's Avatar
I rub like mad on the rear when I have passengers back there. No spacers in the front at all but i still scrub whenever I hit a bump, gilber. I suspect it has more to do with the width tire im running than offset. If I wasnt running the 15mm offset in the rear, I think the tire would be hitting the inner fender pretty bad.
Also, I scrub the front pretty bad when I turn the wheel all the way to lock. I think a 5 mm spacer in the front would go a long way towards fixing that, once i rolled the fenders.
Old Jul 25, 2012 | 08:20 PM
Why you running such big tires?
Old Jul 26, 2012 | 01:14 AM
ibified's Avatar
Because I was able to pick them up from tire rack for $40 for the set?
Old Jul 28, 2012 | 07:36 PM
Ok Wow then good deal. But me the max I would run is 215/45's
I also run with them and need to roll my fenders as well.
Old Jul 28, 2012 | 08:38 PM
ibified's Avatar
Yeah when these wear out I'll be getting either 215/40 or 205/45
ibified
May 11, 2013 12:45 AM
philcjhughes
Nov 24, 2012 04:47 PM
harvey_kamp@psualum.com
Jul 9, 2009 03:17 PM
MC92
May 4, 2009 06:48 PM
TheSteelKnight
South
Nov 24, 2007 11:16 AM
