Fml
Old Jul 16, 2009 | 05:06 PM
gilber33's Avatar
Default Fml
My car was broken into last night. Ripped out my 250 dollar head unit, destroyed the compartment below that. Need new window now.
F@!#!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 16, 2009 | 05:32 PM
TIPSP's Avatar
Got Boost?
Major Sucks man.
Picture that Sh*t. Call your insurance company.
Old Jul 16, 2009 | 07:13 PM
gilber33's Avatar
Anyone have directions on how to replace a window. Front passenger to be exact. I tried searching a little bit, but am a little preoccupado at the moment trying to locate a few other necessaties.
Thank you very much.
Old Jul 16, 2009 | 10:32 PM
850tony's Avatar
i know the feeling man. my eclipse at the time got ripped off in the pedit ice center parking lot by the fair wi fair grounds.... $700 in dash dvd player with sub and amp.... bitches even took my gas.
as for the radio, i have a stock radio you can just have for free if u want it. plug and go.
as for the window, i can help you replace the window when you get a window. check with autoglass specialists. if it is insured you will prolly have to go to a list of places they say you can go to.
Old Jul 17, 2009 | 07:18 AM
gilber33's Avatar
I'm going to call around this morning to find a window and then see what the cost of them just setting the window inside the door (because I have the door panel and everything already off) compared to the cost of the window without installation.
I think I still have the stock one laying around here too, see if I can find it and let you know. I think I'm going to buy an aftermarket one for like a hundred bucks, I'm also looking into security systems that are a little more advanced compared to the stock one. Figured if I'm going to have my car parked down here for a while, probably wouldn't be a bad thing to have.
Old Jul 17, 2009 | 12:10 PM
850tony's Avatar
check craigs for a cheep head unit..
also for an alarm system viper alarms make a bad *** one, few diff price ranges to. just dont let jose' and his buddys install it if u know what i mean...
Old Jul 17, 2009 | 04:29 PM
gilber33's Avatar
haha, if I get one I'll probably do it myself, or go to a legit installation place.
Old Jul 17, 2009 | 05:17 PM
blackbrick's Avatar
Is that what she said ?????
Just kidding , I'm sorry for your loss!
Old Jul 17, 2009 | 05:56 PM
gilber33's Avatar
HAHA. I think it can be tweeked into a "she said". But thanks, it could have been way worse, they could have messed up my interior or my exterior, at least they were nice about it...I guess.
Old Jul 17, 2009 | 06:52 PM
TIPSP's Avatar
Got Boost?
have you seen the original gone in 60 secs(1974)?
You should put a real tiger in the rear seat.
Old Jul 17, 2009 | 07:18 PM
850tony's Avatar
^^^LMAO!!!!
i have done a viper alarm install before so i cud help.
Old Jul 18, 2009 | 12:28 AM
nonsense619's Avatar
IF YOU CAN I WOULD GET ANY OF THE SECURITY SYSTEMS FROM BELOW...GO TO THE LINK PRESS START AND ENJOY.850TONY CAN PROBABLY HELP YOU RIG ANY OF THOSE IF YOU WOULD LIKE..JUST DONT LET HIM CONVINCE YOU TO USE ANY ROCKETS...
http://www.dirtybutton.com/animation...ti-auto-theft/
Old Jul 18, 2009 | 03:01 AM
850tony's Avatar
very nice.
Old Jul 18, 2009 | 04:11 AM
If you have the door panel off, removing the broken window and installing the new one is EASY. The window is held in place with 2 hairpin clips. You can see them through the holes in the doors. I removed my windows to tint them. One hole has a foam piece over it, a little bigger than a business card. I carefully cut mine away with a straight razor so I could put it back. You have to roll the window in the correct position, about 1/3 of the way down to see the hairpins. BE CAREFUL WHEN REMOVING THE CLIPS, DON'T DROP THEM IN THE DOOR, HARD TO GET THEM OUT THE THE HONEYCOMB DOWN THERE. I used needle nose pliers to get mine out. Once you have the pins out, the bottom of the window frame has track guides that hold the arms that rise the windows up and down. The arms have studs that pop out of the plastic track guides. They are a little hard to pop out but you may be able to pry them out of the socket with a screw drive or just use your fingers to push (the window frame) & pull (the arm that raises the window).
Hope things get back in shape for you.
Old Jul 18, 2009 | 08:26 AM
gilber33's Avatar
I was actually leaning more towards flame throwers underneath my car, and then if they are able to get passed that, the tiger would be a great addition. Good idea.
