front speakers just stopped working???
Old Apr 17, 2008 | 07:56 PM
jvcski's Avatar
Default front speakers just stopped working???
Can anyone help My front speakers just stopped working not sure why, anybody have any ideas? Thank you
Old Apr 17, 2008 | 08:20 PM
JPN's Avatar
JPN
Default RE: front speakers just stopped working???
Check fader **** position.
Check fuses.
Pull out the radio and see if all connections are secure.
Pull the speakers out by gently prying off the metal mesh & removing a couple of Torx screws.
JPN
Old Apr 17, 2008 | 08:38 PM
Play with the volume **** and see if they come back and go away again.
The volume ***** inside the radio go bad from time to time.
Old Apr 17, 2008 | 08:57 PM
green850's Avatar
my bet is on loose connection, they jiggle free from opening and closing the door sometimes
Old Apr 17, 2008 | 09:06 PM
Ozark Lee's Avatar
Do you mean the dash speakers or the door speakers?
If it is the dash speakers - since we are all guessing - I will place my bet that you hit a bump and the magnets fell off.
This is what they look like after the magnets and their greenie glue fails:
...Lee
Old Apr 18, 2008 | 04:32 AM
jvcski's Avatar
Sorry I should have been more specific it is all the front speakers the dash and doors and the connections behind the radio are fine. could it be that something inside the radio broke and now they don't work??
jvcski's Avatar
Old Apr 18, 2008 | 08:31 AM
Psaboic's Avatar
If it was one (or even two) speakers I would agree with the magnets falling off (mine did). However, since you said it is all the front speakers, and the wires and connections seem ok, I would lean toward a bad component in the radio itself.
Follow Tech and JPN's advice and see what that does. HOw do the rear speakers work??
Glenn
Old Apr 18, 2008 | 08:42 AM
JimKW's Avatar
Assuming the Fader switch is not all the way down, it sure sounds like something is wrong in the unit to me.
Old Apr 18, 2008 | 10:56 AM
JPN's Avatar
JPN
If the circuit controlling the dash speaker output failed, it's beyond repair unless you're an electronic wiz and can trouble-shoot the circuit (a crack in the solder, a failed electrolytic capacitor ora transistor is an easy component to spot & replace if you can de-solder & solder, though).
Followeveryone's advice, and if it doesn't do, take the front panel off of the radio unit and spray contact cleaner into the volume/fade control ***** and turn them several times. Also spray the cleaner in all connections on the back of the radio. If this doesn't do, find a used unit at a yard and play with the one you have now.
JPN
Old Apr 19, 2008 | 07:45 AM
green850's Avatar
i would just grab i new headunit, i never liked the stock ones
if you pick one up and have any questions feel free to ask me about installing it
Old Feb 27, 2020 | 04:28 PM
Blackpanda58's Avatar
Default Help
All speakers were working fine then one day the front ones started going on and off then they just stopped all for speakers in the front have no sound the speakers themselves still work and when I put the wires together I hear static but no music any suggestions? Tips ? What could possibly be wrong it's a 2003 Volvo s80
Old Feb 28, 2020 | 08:52 AM
things that could be wrong include a) switch selections - move the balance and fader around, change your music source (ie AM/FM/CD), head unit - does it light up, if not check fuses, amp - check fuses, wiring - do you have a spare speaker to plug one of the wires into? check all connections/wiggle wires to see if anything comes to life. Not sure if your year still has the "double din" head unit but if it does, it slides out by popping out the two vertical bars on the edge of the face, then the unit slides straight out. If you have sound in the rear but not either of the fronts, then I'd suspect an issue with the head unit or the amp.
PS - best to start a new thread for new issues. Adding comments on a 12 year old thread can confuse readers.
nyjumpee
2001-2013 model year XC70
Jul 4, 2012 07:00 PM
Dainos
May 23, 2012 11:10 AM
yeagersadler08
Feb 22, 2011 09:00 AM
whyjeffrey
Oct 9, 2009 10:11 AM
cauqazn
Jan 4, 2005 01:05 AM
