fuel pump or ecm bad?
Old Aug 12, 2011 | 07:05 PM
Ex3Cutioner's Avatar
Default fuel pump or ecm bad?
Hello, first off it's a 1994 850 20 valve 250k miles, in the last year the fuel pump cam sensor and some other stuff have been changed, the car will start then stall, the fuel pump primes but don't seem to turn on after the car starts, i jumped the fuel pump and the same thing start stall, i unplug the MAF and jump the pump and it will run, i have tried 2 junk yard MAF and as soon as i plug them in it dies, any help would be great Thanks.
Old Aug 12, 2011 | 08:20 PM
Don't jump the fuel pump anymore since it works ok. Have you checked and double checked for vacuum leaks? Especially around the idle valve? Will if run if you have your foot on the gas?
Old Aug 13, 2011 | 08:32 AM
yes it will idle, but only with the pump jumped (direct power form battery) and the MAF unplugged. Thanks
Old Aug 13, 2011 | 09:00 AM
ddbeckwith's Avatar
Have you checked the fuel pump relay?
Old Aug 13, 2011 | 04:36 PM
i took it apart it looked fine, and the pump primes when i turn the key every time, i unplugged the relay and the pump did not prime, so i don't know what to check next. thanks for the reply
s60-owner
Jun 17, 2015 06:38 AM
dejan_da_dude
Feb 24, 2015 01:17 AM
Jacob Gem Kahler
Apr 29, 2013 08:34 AM
spidersilva
Aug 17, 2011 07:23 PM
