Fuel pump/filter removal
Old Nov 29, 2009 | 10:19 PM
s_moneh's Avatar
Default Fuel pump/filter removal
just to clarify if i'm doing this right, in order to remove both i need to releave fuel pressure, so by doign this i unplug the fuel pump/sensor(from the back passenger side) run the car till it stops gettign fuel, then unplug the battery correct? then i go about changing it all, then i just hook it back up and try to start it and it should run again correct??
Old Nov 29, 2009 | 10:27 PM
Chebucto's Avatar
I found it was just easier to use the release valve (looks like a tire stem) just behind the fuel filter. just unscrew the cap and release the pressure. (have a couple of rags available).
Old Nov 29, 2009 | 10:39 PM
s_moneh's Avatar
aha yea i heard about that aswell but otherwise i'm doing fine and everything should be back to normal correct?
Old Nov 30, 2009 | 09:26 AM
fcpgroton's Avatar
Former Sponsor
You could also start the car and remove the fuel pump fuss. This will work too.
Old Nov 30, 2009 | 02:03 PM
s_moneh's Avatar
i may aswell jsut unplug the pump from the socket cuz i need to replace that, and my god mines stuck in there anybody have any easy ways of getting her out?
timoc663
Aug 14, 2016 05:35 PM
spidersilva
Aug 17, 2011 07:23 PM
jaquelperdue
Jul 19, 2010 09:47 PM
