Fuel pump replacement tip
Old Jun 28, 2013 | 12:02 PM
mungo544's Avatar
Default Fuel pump replacement tip
Replaced fuel pump with a new Airtex module. Worked for a month then started losing pressure. Removed module and found misaligned clamp between module and hose. Replaced factory installed clamp with new clamp, problem solved. Make sure to check factory installed clamps b4 installing pump.
jigen3
Jul 17, 2014 05:19 PM
spidersilva
Aug 17, 2011 07:23 PM
HunnyBunny
Dec 14, 2010 07:18 PM
flyboy
Mar 7, 2006 03:06 PM
