Gauge cluster removal
Old Jul 9, 2006 | 11:38 AM
fast850r's Avatar
Default Gauge cluster removal
How difficult to remove gauge cluster? My gas gauge does not work. Have replaced sending unit in tank but with no luck. Thought I would get a new cluster and replace it, but not sure how difficult it is.
Old Jul 9, 2006 | 12:14 PM
t.d.'s Avatar
Default RE: Gauge cluster removal
Never done it on a Volvo, but I did on my Nissan Maxima and it was surprisingly easy, just be careful not to pull too hard and risk breaking any circuitry connected to the cluster.
Old Jul 9, 2006 | 12:18 PM
https://volvoforums.com/m_17710/tm.htm
Check out that post.
Old Jul 9, 2006 | 03:10 PM
reg's Avatar
reg
TECH, have you ever done a c70?? One of these days the dash bulbs are going to die. The basic c70 is an 850 but the dash is different. Any instructions??
REG
ORIGINAL: tech
Old Jul 9, 2006 | 04:03 PM
They are a little different but not much.
For the most part they are the same.
Haven't done one on a while will have to look at one to see exactly what is different.
Old Jul 9, 2006 | 07:35 PM
reg's Avatar
reg
I had imagined that one pulled the speedo cluster from the front...........after pulling the wheel. Apparently you pull the dash pad off and 'reach in'???? I've done an Audi and BMW and they are rather difficult and of course the coiled spring for the air bag presents a heck of a problem if you don't wind it the correct number of turns. The Volvo sounds 'easier'??
REG
Old Jul 9, 2006 | 09:42 PM
Yes no need to remove the steering wheel.
You remove the top part of the Dash.
Old Jul 10, 2006 | 07:55 PM
reg's Avatar
reg
Thank you sir............I shall keep that in mind as I believe that i will keep the c70........it grows on you! I just picked up a summer auto for my bride. She now has a 06 Mazda MX-5. That little auto is a bargain!!! It is a blast to drive with a 6 speed paddle shifter. If only Volvo made something like that. Of course if it had a 302 Ford pushing against the gears...................
REG
Old Jul 10, 2006 | 09:29 PM
LOL
If you do it and need Help I will always be here.
volvo5volvo
May 29, 2012 05:46 AM
rspi
Apr 1, 2012 07:52 PM
elbows8
Apr 23, 2008 11:12 PM
xkennx
Oct 26, 2006 09:42 PM
