got into an accident
Old May 22, 2008 | 01:33 PM
green850's Avatar
Default got into an accident
well i got into a fender bender in the 850
now i need:
new hood- no can do with the junk yard, all are smashed
new grille-getting an after market one
new drivers side horn-got at junk yard
new bumper- all at the junk yard are smashed
new aircondition condensor (i think thats what it is, infront of the radiator)- are these worth picking up at the junk yard or should i just shell out for a new one?
i'll get pics later, i rear ended a surburban with a trailor hitch and it went right through the car, luckily it didn't get to the radiator (which i had already replaced) and i was only going 5mph or under
my question is, does anyone have a hood or a bumper they are willing to sell for a 1995 volvo 850 GLT (mine is green)?
also where is a good place to get an aftermarket grille?, i'm going to try to bend mine back a little so i can get a grille back in it
Old May 22, 2008 | 01:44 PM
S70driver's Avatar
Default RE: got into an accident
What type of aftermarket grille?
Are you talking a cheap knock off of an OEM or are you talking about like a mesh grille?
You need to look at this thread here, https://volvoforums.com/m_38606/tm.htm
and this one, https://volvoforums.com/m_65537/tm.htm
Old May 22, 2008 | 06:55 PM
green850's Avatar
i was looking at one of the chrome mesh type. any good places to get those?
Old May 23, 2008 | 07:30 AM
JPN's Avatar
JPN
If your evaporator has been replaced, I would go with a new condenser but check with Tech to see what he thinks.
At least it was a fender bender.
JPN
Old May 24, 2008 | 07:55 AM
green850's Avatar
i'm thinking of also replacing my plugs, plug wires, and coil. should all of this stuff be OEM? i've heard of them acting weird with other plugs, i was curious as to other components.
this morning she wouldn't fire for the first time, usually if i push the plugs back onto the coil and make sure they are all snug on the distributer she turns over, but this time it just wont run. it's got gas and the pump is priming , battery is good, i just think the coil is shot. i'm going to go fool with it later hopefully i figure things out
thanks for the help guys
Old May 24, 2008 | 08:03 AM
I would go OEM on the stuff.
Aftermarket parts don't work that well at all.
Old May 24, 2008 | 08:10 AM
green850's Avatar
any ideas on why it won't turn over tech? i'm going to try a new coil first, do they tend to go bad?
Old May 24, 2008 | 09:14 AM
JPN's Avatar
JPN
Any trouble code in the ECU? Camshaft Position Sensor could be one of the culprits.
JPN
Old May 24, 2008 | 12:20 PM
Could be alot of things pull codes first.
Old May 24, 2008 | 01:18 PM
green850's Avatar
unfortunately i can't get it to autozone to get the codes pulled, and i don'thave a reader. i need to shell out a few bones and buy one.
i've been tinkering with it all day, my coil doesn't seem to be drawing spark. i went to the junk yard and picked up a new coil for 20$ (compared to 200$ new) and got it tested at autozone and it tested fine. but even when i put the new one on it still doesnt fire, it cranks and cranks but just doesnt fire. it's on the charger right now if anyone as any ideas feel free to post.
thanks again
Old May 24, 2008 | 03:55 PM
Maybe a cam sensor.
Yours is a 95 you should have the OBDI under the hood and you can pull the codes yourself.
Old May 24, 2008 | 11:30 PM
jnduke's Avatar
Green850,
My local volvo shop in Birmingham has about five parts cars, and they all have intact hoods I think. I don't believe there is a green one though. It seems that the cars fail mechanically that end up at his shop for parts (due to lack of maintenance). I'd keep looking for the used hood- you'll find one. What part of the country are you in? Maybe someone could point you towards a more Volvo savvy automotive recycler- or check with your local body shop, and see if they can order you a used hood.
Is your no start problem related to the accident? or a separate issue?
Old Jun 5, 2008 | 08:30 AM
green850's Avatar
ok i still have had no luck getting my 850 to start.
i replaced the cap and rotar, as well as the spark plugs (which looked horrible, i think they were original) and it still wont turn over
it is getting fuel (checked the fuel rail, sprays very well), timing belt is not broken and is turning, and it cranks normally but won't fire
i also put a new coil on which tested ok autozone. how would i go about checking the cam sensor?
anyone have any ideas? i am pretty stumped on this one, it has to be spark and something that would randomly go out.
Old Jun 5, 2008 | 08:56 AM
JimKW's Avatar
I don't think there is a way to check the cam sensor. When mine went I just replaced it and that was the problem.
Old Jun 5, 2008 | 09:26 AM
green850's Avatar
where exactly is that located? are they any tell tale signs? how much do they run?
Old Jun 5, 2008 | 09:34 AM
green850's Avatar
i'm getting no spark from the coil to the dristributer, or to the plugs
Old Jun 5, 2008 | 10:01 AM
  #17
JimKW's Avatar
It's on the Dirver's side of the cam. I think it's on the intake side, but not certain.
$142 at fcpgroton:
http://www.fcpgroton.com/product-exe...ategory_id/116
Old Jun 5, 2008 | 10:27 AM
  #18
JPN's Avatar
JPN
Clear enough for you, are they?
JPN
[IMG]local://upfiles/6892/010CFF4B5F024E5EBA45F0870B3FB5D2.jpg[/IMG]
[IMG]local://upfiles/6892/359E78FCB43F4510AAFB2192C784D3AE.jpg[/IMG]
[IMG]local://upfiles/6892/2B607EF3606546BD9302B2155ABF38FA.jpg[/IMG]
Old Jun 5, 2008 | 10:29 AM
  #19
JPN's Avatar
JPN
Electrical system problems are PITA.
JPN
[IMG]local://upfiles/6892/01D5EAB7CC6B4ADDAD48A6E58E0083F9.jpg[/IMG]
Old Jun 5, 2008 | 04:39 PM
  #20
green850's Avatar
thanks guys, i'll see what i can figure out.
feel free to post any suggestions
