Ground wires.
Old Nov 13, 2010 | 01:11 PM
regime's Avatar
Default Ground wires.
A while ago i was working on my 240 when i noticed the braided ground wire that runs from the top of the head to the firewall. It's made up of a good number of small wires, and it didn't look all that good. It was pretty corroded and had literally 1 small wire left that holding the end connector on.
So i ran down to a local chain boat store and grabbed some number 8 wire a couple connectors, and some shrink wrap.
Unfortunately i must have lost the pictures of the ones for the 240 (it was impressive how little was holding this together).
However, today while replacing my Vacuum lines on my 850, i noticed that it had 2 of these same kind of wires running from the top of the head to the firewall, and the passenger side fender. Both were in a little better shape then my 240, however still about half of the wires were corroded right though. I found my way back down to the boat store and here's what i got.
Both wires built.
an end.
They are made of all marine quality parts, UL listed connectors and wiring, and the shrink wrap is the best i have ever seen. They parts aren't on the cheap side, but if its made to last in saltwater for years, it should last forever in a car.
Go out and check your ground wires out. If mine were beat i bet yours will be too.
akem21
Sep 26, 2010 08:52 PM
SunnyCatStudio
Nov 11, 2006 03:17 PM
kaz
Mar 14, 2005 05:49 PM
Cypress
Dec 6, 2004 03:17 PM
teamlfr
Mar 7, 2004 12:48 AM
