Headlamp Replacement
Old Feb 3, 2011 | 04:01 PM
WVKarenC's Avatar
Default Headlamp Replacement
I have a 97 Volvo 850 GLT wagon, and the headlight on the driver's side just went out (the little indicator light told me, pretty cool!). The low beam doesn't work, but the high beam still does. Do I have to replace the whole thing (about a $200 part), or is it possible to just put a new bulb in. And how much trouble is it to replace? Something I can do myself, or a major task? Thanks in advance for any info/advice.
Old Feb 3, 2011 | 04:08 PM
91shelby's Avatar
it is easy as pie, you replace the bulb there is a cover, that twists off behind the headlight and you can access the bulbs low beam is part # 9006, high beam is 9005
Old Feb 3, 2011 | 04:16 PM
ibified's Avatar
should cost you about 10 bucks for a bulb. that being said, I would go ahead and replace them on both sides. Just make sure you do not touch the glass on the bulb. if you do, wipe it off with rubbing alcohol. if you go to most auto parts stores, they will do it for you.
Old Feb 4, 2011 | 08:23 AM
WVKarenC's Avatar
Thanks so much! Glad to know I don't have to buy the whole assembly, and it sounds like an easy fix. My first post here, and I love my 850 wagon, so I'll be back. Again, thanks for the good advice.
Old Feb 4, 2011 | 10:49 AM
ibified's Avatar
glad to help!
wagon-dan
1998-2000 model year V70
Apr 2, 2012 06:26 PM
kcmaniac
Jul 15, 2011 07:40 PM
rsjogren
May 2, 2010 06:22 PM
Volvodaddy
Mar 25, 2006 11:39 PM
Volvodaddy
Dec 29, 2005 09:13 PM
