Heated seat switches supposed to light-up at night?
Old Jan 24, 2011 | 11:26 AM
bond007's Avatar
Default Heated seat switches supposed to light-up at night?
As the title says. I recently joined the forums and am looking to find answers to several questions, this being one of them. When I turn on the lights at night, everything lights-up in the interior, except the front heated seat switches, and the winter/economy/sport shift selector button. Both the seat heater switches and shifter selector light-up when turned on, but there is no guide light for them at night, (i.e. I have to turn the dome light on at night in order to find the switches). Are they supposed to be that way? if not, are the bulbs replaceable, or would I need to replace the switches altogether?
Car: 1997 Volvo 850 wagon, non-turbo.
Any help appreciated.
Thanks
Old Jan 24, 2011 | 12:36 PM
ibified's Avatar
Yes they are supposed to light up. As for bulbs: pull the switches out - some have replaceable bulbs and some do not. you'll have to look at the back of the switch and see. If they are replaceable, be prepared to bend over for the bulbs....they are pricey. Do what I did and swipe good bulbs out of junkyard cars.
Old Jan 24, 2011 | 01:25 PM
trektech's Avatar
Default Switch lamps
I've good success just replacing the bulbs while using the bulb holders again. On the backside of the switch you will find the base of the bulb holder. It is white and can be removed with a small straight screwdriver. Turn it 90 degrees anti-clockwise. Unwind the bulb from the holder with a small sharp knife. I get replacement bulbs at Radio Shack, part number: 272-1092 12 volt micro lamp. Two bulbs for less than $2. Good luck.
admasters
Jan 1, 2014 04:25 PM
jdsmith
Jan 26, 2011 06:46 AM
Red October
Sep 16, 2009 10:42 AM
Justos
Jan 18, 2008 01:34 PM
blue goose
Aug 18, 2007 12:30 PM
