Heater core leaking- O rings?
Old Sep 5, 2012 | 02:39 PM
misterbrooke's Avatar
Default Heater core leaking- O rings?
I have a leaky heater core on my 1994 850. From time to time it'll leak large amounts of water/coolant onto my floor, emit steam, etc.; usually when the car is hot or I've driven a long distance. I've gotten to the heater core to take a look at it while it's leaking, and it leaks at one of the joints on the pipe going FROM the heater core; it's located underneath the core.
Does this mean that it isn't the heater core itself that is leaking, but that I'll just need to replace the O rings? When I bought her in February, the heater core had just been replaced, so I'm wondering if they forgot to do the O rings when they put the new one in.
Old Sep 5, 2012 | 05:11 PM
VTBricked's Avatar
It could be just the O-rings, but since you'll drain the heater core while accessing them, you should pull the core and test it for leaks.
Old Sep 5, 2012 | 05:30 PM
If the core has not been replaced within 5 years, replace it. You can get nearly new ones from the jy. The one I pulled the other day had a 9/09 date on it. They usually last 10 years, if they are Volvo Cores.
gentlejax2
May 20, 2011 01:17 PM
s80turbo
Apr 24, 2011 06:31 PM
volvo4fun
May 23, 2010 04:46 PM
wilsontw53
Jan 1, 2010 03:05 AM
Quincy56
Apr 7, 2008 07:39 PM
