HELP
Old May 9, 2007 | 01:51 PM
volvodrummer's Avatar
Default HELP
i was diving my car today and all of a sudden my air cuts on. i tried to turn it off adjusting the controls doesnt work... its blowing nothing but hot air all the time....
any suggestions?
Old May 10, 2007 | 03:33 AM
JPN's Avatar
JPN
Default RE: HELP
Hi,
Is your climate control automatic or is it manual? If auto, try pulling codes from OBD-I terminal, as your 850 is of '93. If there is no code or clearing the codes doesn't help, pull out the climate control unit and disconnect the connectors, clean them with air duster and reconnect them to see if ti cures the problem. If it still doesn't help, the blower motor resistor may be the suspect, though you should still be able to adjust the temp.
Play with it and tell us a bit more findings if possible.
JPN
shop2
May 1, 2011 07:32 AM
lydjan37
Sep 13, 2010 07:11 AM
dennisimo69
Apr 16, 2008 06:38 PM
markjenross
Nov 7, 2007 08:02 PM
denbass
Oct 23, 2007 03:45 PM
