Help!
Old Jun 2, 2011 | 06:06 PM
DustyB's Avatar
Default Help!
Driving around with no problems and without warning lost all power, got back to a friends house but now it idles really hard, and if i let off the gas it dies. anyone know what it could be? 1995 850 turbo.
Old Jun 2, 2011 | 06:31 PM
ibified's Avatar
10 bucks says you either ripped an intercooler hose or blew one off the coupler. Check all your hoses for leaks.
Old Jun 2, 2011 | 07:17 PM
DustyB's Avatar
ok, if you could list a few things before i have someone tow it(70 miles from my town) i will check the hoses.
Old Jun 2, 2011 | 07:19 PM
Mad Matt's Avatar
I'm gonna guess MAF related.
Forgot to plug it in once and I had a really rough idle and I had to keep my foot on the gas to keep the engine running. Once I let off the gas, the engine died.
Also blew my throttle body hose off. Car still ran and idled just fine, just had VERY week acceleration.
Old Jun 2, 2011 | 07:20 PM
Mad Matt's Avatar
Check all the vacuum lines and hoses that connect your turbo to the IC then to the throttle body.
But I still think it may be MAF related.
Old Jun 2, 2011 | 07:25 PM
MattyXXL's Avatar
Where you beating on it before It died?
What about a PVC issue?
Has it happened randomly before?
Old Jun 2, 2011 | 07:32 PM
ibified's Avatar
Intercooler hoses are the large (2+ inch diameter) that come from the turbo over the spark plug cover to the intercooler, and then go from the intercooler to the throttle body. I had one essentially explode on me a while back and i had the same issue.
Old Jun 2, 2011 | 08:12 PM
DustyB's Avatar
was driving about 45 mph, then it just slowed way down and wouldn't let me get power above 3k rpm. the temp wasn't up all the way to red but it was just a little above half.
Old Jun 2, 2011 | 08:13 PM
ibified's Avatar
temp sounds normal. Car went into limp mode if it wont go above 3k RPM. Check engine light on? codes?
Old Jun 2, 2011 | 08:29 PM
91shelby's Avatar
+1 on MAF related. when i first got my wagon i had similar issues and it was due to the MAF good luck
shop2
May 1, 2011 07:32 AM
lydjan37
Sep 13, 2010 07:11 AM
dennisimo69
Apr 16, 2008 06:38 PM
markjenross
Nov 7, 2007 08:02 PM
denbass
Oct 23, 2007 03:45 PM
