Help with AC problem
Old Jun 5, 2008 | 09:38 AM
je850's Avatar
Default Help with AC problem
AC was not cold enought once it got hot. I recharged it but it only 1/2 can at most but it worked fine. Then yesterday I was stuck in trafic for about 10 min and at the end ac went hot. After I started moveing it got cold agan. Then after about 1hr of hy driveing it sarted to get hot again but not for very long 1 min at most two or three times in 10 mins also had fog comming out. Then started working fine again.Any one have any ideas
Old Jun 5, 2008 | 10:06 AM
JimKW's Avatar
Default RE: Help with AC problem
Probably the evaporator. Known to go bad on these cars. Any where from $1300 to $1600 to have it done. Two days of tough work to do it yourself and then you have to have somebody charge it for you.
Old Jun 5, 2008 | 10:38 AM
je850's Avatar
Well if it is I will have to replace it myself but I do want to make sure thats it before takeing on such a big job
Old Jun 5, 2008 | 10:50 AM
Ozark Lee's Avatar
Check the A/C clutch gap first.
...Lee
Old Jun 6, 2008 | 08:41 AM
Psaboic's Avatar
Good call on the compressor clutch gap. I would suggest checking that as well just to be sure, but I too suspect the evaporator
Old Jun 6, 2008 | 11:04 AM
Systek's Avatar
sooo, how do you check the clutch gaP???
Old Jun 6, 2008 | 11:41 AM
JimKW's Avatar
It's right at the top of this forum:
https://volvoforums.com/m_34431/tm.htm
Old Jun 6, 2008 | 01:36 PM
je850's Avatar
From what I have read it seems that the main problem with the evaporator is leaking. If that is true would that not rule out the evaporator. I did have to add some gas but it did cool just not enought when it got hot allthough it did cycle on and of. I got the car in april and it had been sitting for 3 months so I woulg think that it has not been charged since last year at the earliest.
Old Jun 6, 2008 | 01:48 PM
JimKW's Avatar
You should NEVER have to charge them. If you do it's leaking somewhere, and the most likely culprit is the evaporator. When it is low on R134A it will cycle on and off until it is too low and then it will not come on at all. When it is fully charged it will stay on until it reaches the coolnes set in the car.
Old Jun 6, 2008 | 03:43 PM
Ozark Lee's Avatar
There is also some good stuff on the clutch gap here:
http://volvospeed.com/vs_forum/index...howtopic=16658
and here:
http://volvospeed.com/vs_forum/Ac-Th...ch-t76833.html
Be sure to read N8-50's pdf writeup.
And then there is the ghetto fix here:
http://volvospeed.com/vs_forum/index...howtopic=80181
...Lee
Old Jun 7, 2008 | 09:57 AM
Systek's Avatar
...Lee
what's wrong with the "ghetto" fix if it works??? plus if the clips ever fall out, they are made of plastic and will hurt NOTHING....unless someone can convince me to do the job right on this commuter car, I see no reason why this isn't a better option...
Old Jun 7, 2008 | 10:59 AM
Ozark Lee's Avatar
I never said there was anything wrong with it. I've never tried it so I don't know how well it works.
As an engineer I tend to be very precise when I repair things but I've also MacGyvereda lot ofstuff in my life when I'm in a pinch.
...Lee
Old Jun 7, 2008 | 01:08 PM
JPN's Avatar
JPN
Lee, you're always welcome in a gas-turbine engine shop.
BTW, is MacGyver still around? That also reminds me of the pilot for the Air Wolf (the modded Bell-222 rotorcraft that flies at Mach-1 without suffering shock wave stall on the rotor blades) and the driver guy for that Pontiac Knight-2000 (David Hasslecough or something of that sort).
Good old 80's...
JPN
Old Jun 8, 2008 | 06:04 AM
Volgrrr's Avatar
Sometime the A/C system can suck in a slight amount of moisture over time and, if this happens, when the A/C is turned on, the moisture in the system will 'ice' up fairly quickly.
The system will then shut down until the ice melts and the cycle starts all over again.
Its probably not the cause of your problem, but it's just my $0.02 worth.
Old Jun 8, 2008 | 02:16 PM
Systek's Avatar
ORIGINAL: Volgrrr
when this happens, isn't it cause the drier no longer works?
Old Jun 8, 2008 | 02:41 PM
Ozark Lee's Avatar
What's up with our apostrophes? I tried to edit my previous post and it still came back doubled in every instance. I wonder what will happen if "quote"?
[sm=smiley25.gif]
...Lee
james_caza
Mar 8, 2010 02:54 PM
dennisimo69
Apr 16, 2008 06:38 PM
markjenross
Nov 7, 2007 08:02 PM
denbass
Oct 23, 2007 03:45 PM
bluejohn
Engine & Internal
Dec 1, 2005 10:47 PM
