Help guys, I need to fix/replace a leaking ABS pump. (Teves IV?)
Old Jun 15, 2012 | 03:22 PM
1995Volvo850's Avatar
Exclamation Help guys, I need to fix/replace a leaking ABS pump. (Teves IV?)
Guys, I'm helping work on a relative's 1993 Volvo 850 GLT Automatic Non-turbo Sedan and need some help either fixing or locating a new ABS/traction control pump called the Teves IV (I believe that's what it's called. It has the four lines coming out of it.)
It seems to be leaking not from any of the four fittings but rather somewhere underneath, and leaks about a full tank of brake fluid in one day.
I have heard this is a common issue, but what fix do you guys recommend?
Also, I have been looking for this part, but it has been very hard to find, but those who do offer it charge a fortune.
I appreciate all the help I can get!
1995Volvo850
Old Jun 15, 2012 | 04:21 PM
Here is an update:
It seems that the pump is leaking fluid from that rectangular black piece on the bottom. If you wipe that piece totally dry, pump the brakes, and go back to check for fluid leaking you will find that it has made a mess on that part again.
Any ideas?
Thanks!
Attached Thumbnails Help guys, I need to fix/replace a leaking ABS pump. (Teves IV?)-photo-jun-15-4-40-40-pm.jpg
jackson2600
Nov 15, 2023 02:04 AM
drenman
Nov 29, 2016 07:35 AM
IRMB
Oct 28, 2013 10:40 AM
theotherpilot
Jul 10, 2009 12:28 AM
Volvorator
Mar 15, 2007 10:37 AM
