Help: Oil Leak!! :(
Old Jan 25, 2010 | 05:33 PM
850T5M's Avatar
Default Help: Oil Leak!! :(
So I bought my car about 3-4 months ago, its a 94 850 Turbo. When I bought the car, the man told me it was leaking oil, but barely from a hose. The day he sold me the car, he took the liberty of changing the little o-ring that was leaking, he changed it with me actually...3 months later its leaking again, from the same place.
The O-ring i'm talking about is located on the radiator, on the passenger side, at the top; its right under the coolant hose i believe. Any ideas?
P.S. The O-ring that we put is a genuine volvo o-ring, to ensure proper size and fitment, also it comes with this metal clip that holds the hose in place.
Thanks in advance
Old Jan 25, 2010 | 08:05 PM
fcpgroton's Avatar
Former Sponsor
The only thing I could think of that would cause it to leak again would be if it did not seal well the first time. Did you clean out the radiator connector to make sure it was free of any dirt?
Old Jan 25, 2010 | 08:06 PM
850T5M's Avatar
No I think the guy simply put a new O-Ring and pushed it back in...wouldn't be a pressure related problem or anything like that would it? :S
I just find it weird that I juts changed it and its leaking again...
Old Jan 25, 2010 | 08:09 PM
fcpgroton's Avatar
Former Sponsor
It could be, but that would mean the oil pump is building to much pressure. How are the rest of your seals? If there not leaking then I would think it is not a pressure issue.
Old Jan 25, 2010 | 08:46 PM
850T5M's Avatar
Rest of the seals are perfectly fine, haven't seen anything else leaking...maybe its just dirty. Im gonna go get some more Rings from my volvo dealer and change it again, im gonna clean it well this time...hopefully it stops leaking.
Old Jan 25, 2010 | 08:58 PM
I had a simular problem with our S70. It was a joint from the line. Check this out: http://www.atthetipwebs.com/technolo...T_oil_line.htm
Old Jan 25, 2010 | 09:02 PM
850T5M's Avatar
Nah its not the same problem, thanks anyways tho...I'm gonna keep it in my favorites incase it ever starts leaking! lol
My leak is connected to the Rad, near the top of the engine...i'm pretty sure its just the o-ring was badly put or its dirty...gonna check it tomorrow when I get home from school
Old Jan 25, 2010 | 09:06 PM
Did he replace the o-ring that goes in the fitting or the clear one between the hose and fitting?
If he did not replace the clear one I would try that first.
Old Jan 25, 2010 | 09:09 PM
850T5M's Avatar
He replaced both of them, and put a new metal clip, its weird that its leaking again.
Old Jan 25, 2010 | 09:11 PM
The top of that oil line connects to the radiator. Maybe there is a crack in the line or radiator???
Old Jan 25, 2010 | 09:12 PM
Also make sure he did not tear the o-ring some installing it.
Old Jan 25, 2010 | 09:18 PM
Step 19 of those instructions have a picture of the oil line connection. Is that where you replaced the seal?
Old Jan 25, 2010 | 09:23 PM
850T5M's Avatar
The radiator is a few months old, he installed it a few months before selling the car. Step 19 is the exact place that's leaking!!
dlleo
Feb 29, 2012 05:31 AM
ROBLU540
Feb 20, 2009 07:59 PM
enigma9011
Sep 1, 2008 08:06 AM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
