High idle RPM after T5 throttle body cleaning
Old Jul 15, 2012 | 09:42 AM
And1one's Avatar
Default High idle RPM after T5 throttle body cleaning
I cleaned my throttle body today from my T5.
Some reason, car is now idling with high rpm:s after that.
Used some brac clean to clean it, and fastly flushed it with gas, and carefully cleaned with care with compressed air.
What i could have messed with?
I went to drive it and it didnt show me any engine problem lights.
Sprayed start pilot all around throttle body but no affect so its not air leak either...
Please tell me what i have prolly messed up there lol
Old Jul 15, 2012 | 11:10 AM
ibified's Avatar
how high its it idling?
Old Jul 15, 2012 | 12:44 PM
And1one's Avatar
problem solved, ty anyways! assembled it carefully again and setted idle right, now its perfect
Old Jul 15, 2012 | 05:12 PM
I'm not sure what Brac Clean is but a throttle body's plate is coated with an anti-corrosion material that can be stripped off by things like carb cleaner. It's always a good idea to use only a throttle body specific cleaner on them. Doesn't have anything to do with your problem but just a FYI in case someone getting ready to do theirs is surfing this thread.
The reason for the coating is due the close tolerance between the plate and the bore when it's idling as almost all the air for idle is coming through the idle air control motor. If the plate gets corrosion on it's edges it could get sticky or jam in the bore.
Ryan Baker
Jun 19, 2020 09:23 PM
treestone27
Apr 29, 2014 07:40 AM
yoyoman
Apr 2, 2011 05:39 PM
go2sharks
Jan 21, 2009 10:24 PM
proudmonkey
Jul 21, 2005 10:01 PM
