Home Made Camshaft Locking Tool
Old Oct 4, 2007 | 05:00 PM
floryed's Avatar
Default Home Made Camshaft Locking Tool
Can anyone tell me what thedimensions of the slots on the cam shafts are, and the centerline distances between them are? I'm trying to make a tool to hold the camshafts in alignment so that I can work on it, but my book does not give me the dimensions to the home made tool. Can anyone help me with the dimensions on this tool, or give me the dimensions of the camshaft slots and the centerline between them?I'm trying to change the oil seals, and the book is telling me that I need a tool to hold these things. I need to make this tool at work, and I need my car to get there, so I can't take it apart and measure it because I'll never get to work to make the tool. :-) Thanks!!!
Old Oct 4, 2007 | 09:02 PM
JPN's Avatar
JPN
Default RE: Home Made Camshaft Locking Tool
Hi Ed,
As I do not have the 850 any longer, I am unable to measure the dimensions. I can only give you an attachment. Please note, that I'll have to delete it within the next few days so be sure to save it in your PC.
And wait to see if someone else can reply with correct dimensions.
Good luck,
JPN
Old Oct 5, 2007 | 03:12 AM
Maxbaby's Avatar
The Haynes manual also has a description of such a tool. Don't have the manual in front of me, but I believe they were using two strips of steel in a standard thickness about an eighth of an inch thick. What manual are you referring to?
Old Oct 5, 2007 | 08:18 AM
floryed's Avatar
Using the Hayes repair manual (bout an inch thick book). I can see the tool, but I can't seem to find where the dims are at.
Old Oct 6, 2007 | 08:43 AM
The tool would be a pain to make.
If you are only replacing the seals it really isn't needed.
You can mark the pulley good.
Then make a mark on the pulley and cam.
Then you will be fine. If the cam moves when you take the belt off just reposition it when installing the belt.
I only use the cam tool when doing seals on the newer cars with VVT.
Then cam moves when the pulley stays still.
Swish
Intake, Headers and Exhaust
22
Apr 10, 2015 02:57 AM
tech
Mar 25, 2014 09:11 AM
BILL_MCCASSEY
Dec 2, 2008 10:18 PM
tech
May 5, 2008 06:47 PM
