Horn stuck on?
Old Feb 23, 2008 | 07:34 AM
Default Horn stuck on?
If you happen to have the horn stick on on your car this is what you will need to buy and install.
I have seen a few times that the SRS contact reel is also bad. But 99% of the time it is the steering wheel connections.
It can be purchased here.
http://www.ipdusa.com/Volvo-850/Inte.../p-72-158-548/
http://www.odometergears.com/subpages/volvo.html
http://www.fcpgroton.com/volvo850other.htm
Old Nov 17, 2008 | 07:28 PM
Adrenalin540's Avatar
Default RE: Horn stuck on?
Here is a down and dirty way to repair the horn for <$5
Same stuff, do all the safety stuff first...Batt disconnected and get the airbag out of the way, broken parts can be replaced, broken people cannot! SAFETY FIRST. Make sure the car is on a level surface...some airbag switches use Mercury switches that sense vehicle angles and will activate the Airbag...so just play it safe...keep the vehicle level!!!
1. Go to Lowes and get this stuff
http://i312.photobucket.com/albums/l...eceiptcopy.jpg
2. Drill the Horn Brace for the grommet...I put some tape on the drillbit to prevent it from going in to far...
http://i312.photobucket.com/albums/l...DrillBrace.jpg
3. Clean up the mess...also make sure you clean the 'burrs' on the backside of the brace...they are kind of a PITA to get to but be patient...this repair will cost <$5...
http://i312.photobucket.com/albums/l...ir/Cleanup.jpg
4 Identify broken part...it will look like this and the plastic will be broken around the edge...you will see it...
http://i312.photobucket.com/albums/l...BustedPart.jpg
5. Make some homemade washers. I made mine out of an empty milk jug...I used a 12mm socket as the outside template and I think it was a 4.5mm socket for the inside...you only need 2 of these...
http://i312.photobucket.com/albums/l...asherscopy.jpg
6. Put the washer around the grommet and work it in place from the back side towards the front...it goes in pretty easy...
http://i312.photobucket.com/albums/l...ackforward.jpg
7. Work the grommet in place with a fine jewlers screwdriver...if you don't have one any fine pointed object will work, just DON'T mess up the grommet...
http://i312.photobucket.com/albums/l...ewlerssc-1.jpg
8. You can follow Techs advise from here forward...pretty simple.
9. The only addition I may want to add is do NOT OVER TIGHTEN THE NUT on the backside! once it is snug...I put some 'GORILLA GLUE' on the backside to prevent it from coming loose... Pretty simple repair...<$5
Old Jul 14, 2012 | 01:34 PM
jrogers1126's Avatar
Default missing photobucket pics
Adrenalin540, thanks for the tips, however can you repost the images? Looks like they have all expired, and I'm having trouble figuring out what "this stuff" from Lowe's is.
Riculus
Jul 15, 2021 06:44 PM
SamXC70
Dec 6, 2012 06:43 AM
amotin
Dec 12, 2008 09:13 PM
harvey
Jun 22, 2005 10:54 AM
harvey
Jun 22, 2005 03:47 AM
