XC70 horn stuck
Old Jan 28, 2012 | 12:36 PM
SamXC70's Avatar
Default XC70 horn stuck
Does anyone know, on a newer model - >06 - what's the likely culprit if one horn is stuck on AND the other horn blows the fuse if its connected? I'm guessing there's a bad horn, but maybe also a stuck relay - if there is a relay? Or might the switch be stuck on the steering column?
Old Dec 6, 2012 | 06:43 AM
volvo v70 2.4t slamming's Avatar
Hi Sam,
Wondering if you found a resolution to your horn problem. I have a 2006 xc70 with the same exact problem. The horn started going on randomly one day and then just stuck on. After about an hour, it finally stopped. Turns when I checked the 15 amp fuse under dash, it was blown, so I tried replacing. The second it touches the contact it blows the fuse.
Riculus
Jul 15, 2021 06:44 PM
tech
Jul 14, 2012 01:34 PM
amotin
Dec 12, 2008 09:13 PM
harvey
Jun 22, 2005 10:54 AM
harvey
Jun 22, 2005 03:47 AM
