How do I remove the fuel rail on '94, 850
http://volvospeed.com/vs_forum/index...howtopic=29650
http://volvospeed.com/vs_forum/index...cv+replacement
The rails and injectos don't need to come off. Just the feed and return lines. I would suggest picking up some replacement fuel injection line from an autoparts store to replace the old line. This also allows you to cut your old line, making it easier to come off.
Nick
Nick
You don't need any pics. Disconnect the line to the rail on the right side (i.e. passenger side) 17mm IIRC. Then lift off the cover plate, unplug the injectors, and remove the 2 bolts securing the rail to the intake manifold. After that, pull each injector gently along the rail and the injectors will free. (still connected to the rail) From there you can take them off one by one, or test them individually still on the rail. If you are looking for resistance readings, there is no need to take them out. If you are trying to clean them though, or need to remove the rail for other reasons, Follow the above instructions.
boarders123
06-23-2012 09:16 PM
