How to remove rear door windows?
Old Jul 22, 2009 | 10:20 AM
Tom.'s Avatar
Default How to remove rear door windows?
Hello,
I've been thinking on tinting the rear windows, but after I removed the door panel, I discovered that the window was under another panel. Is it too hard to remove the windows and should I consider an alternate tinting method?
Old Jul 22, 2009 | 01:39 PM
gilber33's Avatar
I don't know what the back ones are like, but the front ones you take off the door panel, and that other "panel" doesn't come off, that's part of the volvo safety thing, there should be some holes or slots in the door where you can reach your hand in and a socket wrench to undo the clamps from the track that hold the window in. It's a good deal of work. But like I said, that was for the front windows, I assume the rear doors are similar.
Old Jul 22, 2009 | 04:11 PM
Tom.'s Avatar
But the window is longer than the frame. How should it be taken out?
Old Jul 22, 2009 | 04:13 PM
gilber33's Avatar
You have to remove those "seals" at the bottom of the window, it opens up the slot in the door and then you should be able to tilt the window and slide it out. That's how the front one was done, I'm assuming it's fairly similar for the rear.
Old Jul 22, 2009 | 05:16 PM
Tom.'s Avatar
Okay, I'll check it out. Thanks a bunch.
Old Jul 22, 2009 | 05:21 PM
gilber33's Avatar
no problem
mjohnny
Mar 18, 2013 02:35 PM
kedowi
Mar 2, 2012 12:14 PM
marleyrose
Nov 1, 2010 02:20 PM
Veloce
Oct 29, 2009 06:25 PM
mauriciogalvao
Feb 17, 2009 06:26 PM
