Hp?
Old May 11, 2006 | 04:58 PM
tupapison's Avatar
Default Hp?
I will be buying an 850 T-5 SOON!!!! the guy said its a GLT also? i would like to know how many HP does it have
Old May 11, 2006 | 06:25 PM
rp850's Avatar
Default RE: Hp?
GLT and T-5 use different turbos. Don't know what year you're looking at but the GLT uses a light pressure turbo and makes about 190hp. The T-5 or Turbo models use a high pressure turbo and make anywhere from 222 to 240hp.
Old May 11, 2006 | 06:32 PM
tupapison's Avatar
Default RE: Hp?
Its a 1996 T5, so i guess it has 240HP, is there any mod out there for it to be better? like more hp?
Old May 11, 2006 | 08:22 PM
JimKW's Avatar
Default RE: Hp?
96 T5 has 222 HP. The 850 R has 240 hp. The GLT has 190 hp using LPT.
Old May 11, 2006 | 08:30 PM
tupapison's Avatar
Default RE: Hp?
Oh cool!! thanks, i will try the car tomorrow again
Old May 11, 2006 | 08:31 PM
tupapison's Avatar
Default RE: Hp?
Oh, then 222Hp is still good, what can i put in the engine so it can go faster?
Old May 11, 2006 | 08:43 PM
JimKW's Avatar
Default RE: Hp?
Mainly exhaust and computer upgrade. Search this site and volvospeed.com and you will find plenty of information. Seems like people just keep asking the same questions over and over instead of looking through and searching for answers. Look for some replies and posts from S70driver he has put quite a bit on about upgrades.
Old May 11, 2006 | 08:47 PM
tupapison's Avatar
Default RE: Hp?
Hmm, ok thanks
Old May 13, 2006 | 07:34 PM
tupapison's Avatar
Default RE: Hp?
ORIGINAL: JimKW
About the GLT, what do you mean LPT?
Old May 13, 2006 | 08:32 PM
rp850's Avatar
Default RE: Hp?
Light Pressure Turbo (LPT) vs. High Pressure Turbo (HPT) LPT puts out 8 psi while HPT puts out anywhere from 9.7 to 12 psi depending on model year and whether or not it's an 'R' model.
Old May 13, 2006 | 08:35 PM
S70driver's Avatar
Default RE: Hp?
For starters search. However your best bet is a 3" downpipe mandrel bent of course and a 2.5" catback system unless you plan to put in a bigger turbo then go full 3" on the catback as well and of course in both cases use a HIGH FLOW CAT and a FREE FLOWING muffler. Also you could make a custom RIP kit (Reverse Intercooler Piping) or buy the one EST EST sells. There are really no good intake systems aftermarket for us, but the stock setup is the best, you could also get EST's intake kit or try Slaters DIY intake kit which is linked somewhere on this forum as well as Volvospeed Volvospeed . Guys over on VS are also putting in N/A (Naturally Apirated, meaning no turbo or supercharger) cams. Read about it over on Volvospeed. Also a good ECU tune should be done. RICA ( The U.S. dealer is Viva Performance ) They are exspensice but will give you the best tune for an ECU upgrade. IPD IPD is also one of the best, also expsensive as well. EST also has an ECU upgrade for the nest highest amount, then Upsolute, then SpeedTuning USA. I would go with RICA and or IPD if I were you.
Also a good note to make is that you shouldn't or well not shouldn't but a could idea not to do these upgrades until STAGE 0 is complete, read about it over on Volvospeed in their Performance PINNED section.
VMS
FCP Groton
LPT = Low Pressure Turbo, which in turn means that it isn't boosting as much as an HPT = High Pressure Turbo. I would say that an LPT turbo pushes about 5-7 PSI, like my little 13g did stock.
Old May 13, 2006 | 08:36 PM
S70driver's Avatar
Default RE: Hp?
By the way EST is linked in there it reads EST and then EST again, the second EST is the link.
