Ideas for car not starting when warm?
Welcome all!
Well, only thing I can think of for my '94 850 non-turbo is the coolant temperature sensor making the engine flood. It just cranks and cranks after it has been running for over a few minutes. I plan to probe it when cold and see if the resistance changes consistantly while the engine is warming to rule it out. Any other ideas? I havnt checked for spark yet. Common problem? Thanks everyone - Dave and Bri! |
RE: Ideas for car not starting when warm?
I vote coolant temp sensor as well.
Yep. You should have a check engine light and a code too. Ours did when the sensor went bad!
Thanks guys! We will check the codes manually now. But where is the sensor by the way, i though I could easily spot it but I am missing it? Thanks!
Somewhere in there:).
JPN [IMG]local://upfiles/6892/768255097B784315901B39DED017BF97.jpg[/IMG] |
The coolant temp sensor is mounted in the thermostat housing.
Thanks guys!
Weel with your help, I located it and put a meter on it. 5.5K ohms at 45 degrees, steadily decreasing to 250 ohms at about 180 degrees. So that seems to be working correctly. Any other ideas? I have to try to make this happen again then check for spark... |
According to my book the hot setting is a little low at 176F it should be 300 ohms.
You might also want to make sure the thermostat isn't broke internally. |
