Immobiliser cut off
Old Jan 7, 2010 | 02:35 PM
radio16's Avatar
Default Immobiliser cut off
well now i have a!!BIG!! problem - ive tried turning the key 5 times and resetting my fob which is actually broken - ive tried disconnecting the battery - ive removed the ecu chip - ive held the odo button while turning key to pos II for 30 sec -ive gotten into car and locked all doors , make sure all windows are up, trunk is closed correctly, hood is down and locked - nothing -ive removed the immobiliser fuses #4 & #8 and reinstalled-- i think ive done about all there is to do - it ran fine yesterday but after i locked it up for the night - today nothing- battery shows 13.6 volt fan relay works though - every time i turn the key the radiator fan comes on the cars dash lights up- i can hear the pumps and relays clicking but no engine turn - brand new battery can some one advise on next step- hot wiring relay 210 &211 may be next step, but i really dont want to do that
unless its a lasst resort
Old Jan 7, 2010 | 06:41 PM
radio16's Avatar
Default Any help
is there anyone with any idea? - it ran fine the other day- and before i closed up shop for the night i hit the fob to lock the doors - the red light in the middle of the dash is blinking - i can unlock the doors and lock them with fob again - problem is when i put key in ignition and turn it - normal lights on-then when i turn key to start car i hear very hushed buzzing from pumps- but no engine rotation - i assume the immobilizer is in effect here - how can i reset it - PLEASE ADVISE! -
p.s. starter has been pulled and tested o.k.- solenoid has been pulled and tested o.k. -alternator pulled and tested o.k.-battery new- all fuses replaced with correct amperage none blown- all relays testing correct as far as i can tell
- its got to be the F*&^ING IMMOBILISER!!!!!! god i hate that thing-
Old Oct 9, 2014 | 05:51 AM
joe_unit41's Avatar
Default Volvo c30 2007/2008 2.0D R-design Immobliser
Hi Radio16
I am currently having some issues starting my Volvo c30, when I turn the key the car is unresponsive and there is a message displayed on the screen which says 'immobiliser, try again'.
I have tried everything have have in your post also and I've had no luck.. What did you do in the end?
Old Oct 9, 2014 | 01:28 PM
H0lD mY d6InK's Avatar
Crankshaft sensor will cause a no crank situation as well. You already checked alternator, battery, and starter as those will cause a no crank also.
joker834
Nov 13, 2007 08:20 PM
wheelpin
May 17, 2007 02:21 PM
Gonzspeed
Feb 21, 2007 10:27 PM
Riculus
Nov 17, 2005 01:30 AM
Andres
Feb 28, 2005 07:27 PM
