The infamous Volvo 850 "My car dies while driving but starts no problem" problem...
Hey everyone,
Please help!
- 1993 850 GLT
- car dies intermittently while driving ie once every two days or so
- no warning lights on dash when this happens (check engine,etc)
- pull over, restart car and starts fine
- go home and check error codes - nada. All are clear (1-1-1)
I originally posted this as a possible cam sensor fail again but since the post the "stalling" has happened twice and hasn't revealed any error codes including 3-1-4 (cam sensor). So I started reading and noted some posts about FUEL PUMP AND RELAY?
I don't mind doing the old "blind troubleshoot" intermittent by replacing a few inexpensive relays but I hear this FUEL PUMP on these things isn't cheap so any advice someone can give would be greatly appreciated. Man this would be so much easier if the car would just die completely wouldn't it?
First right answer gets a 24 of Labatt Blue mailed direct haha!
Thanks!
Please help!
- 1993 850 GLT
Thanks!
you can try to resolder fuel pump relay.
http://www.matthewsvolvosite.com/for...pic.php?t=9681
http://www.matthewsvolvosite.com/for...ic.php?t=13806
Yes, cool article, I read that earlier. I had no idea relay problems were so common on these vehicles. I plan to check the relay tomorrow. Any idea what the output voltage to the pump should be coming off this relay? Is it higher that 12V?
No, the output should be '12' volts (close to your battery voltage).
The relay might have two problems.
Burnt contacts that can be cleaned with some very fine sand paper (1200).
And the normal bad solder joints and leaking capacitors.
Okay, checked it out, relay looks damn-near new - no cap leakage, bulge, bad solder joints, anything.
I was going to ask if there is any basic test for this thing other than continuity, voltage, etc, but being an "intermittent" problem any short term test will most likely yield only postive results (as the car runs most of the time, just quits every other day or so). Looks like I'll be borrowing the old lady's beater for this Friday's road trip lol.
Someone recommended hooking up a test light and taking note of it while driving ie if power is lost to the pump, but that involved splicing a few wires, not sure if I'm up for that.
Any hopes that "intermittent" will turn "permanent" anytime soon or do these Volvo quirks go on forever, or at least until I find a mechanic that doesn't play the "I think it's this" game after several tows and an empty wallet? ;-)
I havent seen a case where this kind of 'intemttent' problem has gone 'permanent' but the frequency goes up eventually. You will not have to splice any lines but will have to just connect the test light wires to the wires in connector for fuel pump just behind the rear seat and route them to a location where you can monitor the light. Thats the sure shot test for ruling out the possibilities of bad elecrical/component.
Now THAT sounds alot easier and cheaper thx! I'm going to try that.
Come to think of it - the more I think about the symptom (unlike when my cam sensor went and the llambda light came on just before quitting) - the car does die similar to that of running out of gas. And since there are no error codes (from all the research I've done the ECU does not monitor the fuel pump or relay, correct???) I'm starting to think we're on the right track with a fuel related problem.
I'll get working on that test light this afternoon. Glad I'm on holidays phew! thanks dudes. Any other ideas I'm all ears!
Okay have it hooked up and will monitor.
But in a related post that I posted I got a fellow now talking about the MAIN relay on top of the radiator:
Ah okay I gotcha. It's grey with No. 3 545 803. I've come to know this typically as the "MAIN RELAY" rather than injection relay, sorry. Visually inspected the relay, nothing obvious. Is there a TSB related to this? How do you test one of these? Or am I going to end up like everyone else (including a Volvo mechanic I know) just randomly replacing relays until the problem goes away?
I'm starting to think this car is a real piece of work. Never had these types of "intermittent" problems with any other vehicle I've owned (GM, import, etc).
Is this The Almighty's way of telling me (and the rest of us schmucks out here with the same problem) that the 850 is a turd on wheels?
I have a 1993 Volvo 850 GLT, with about 200K, that is doing the EXACT SAME THING! Every mechanic has told me they dont know what is up, they have offered to replace every relay, for hundreds of dollars, or they have just showed me the door because it can not be reproduced! So, if you have figured it out, please let me know, you can email me at my yahoo address, it is my user name here musicmansing5555 at yahoo.com. Thank you so much for your help
Okay
You are complaining about a <$50 item in a car that is most likely in better shape than anything you could find in the price range. "PLEASE" show me a 93 GM or import that is as good. I won't hold my hand and on my *** waiting.
Everyone is buying these old tanks because they still run and and they don't cost much to buy and they are still, after all of these years comfortable and safe. So for a few bucks you tell us they are a turd on wheels? Good for you. If you'er ever in Florida let me know and I'll show you what a little bit of work will get you in a 14-17 year old 850.
Maybe a Corsica would suite you better.
Replace the fuel pump relay.
Make sure you get a new RED one not an old style green one.
I also own a 1993 850 & had the exact same problem where it would just die while driving along.
Several mechanics charged me a lot of money but none could fix it.
I replaced the relay 6 months ago and it's run perfectly ever since.
Did it myself it's easy and the part is pretty cheap too.
Check your fuel pressure, especially when stalls, at the schrader valve on the fuel rail. Normally 44 psi b/4 engine started, about 35 at idle. Low or no fuel pressure would confirm if there is fuel related issue. A very weak pump or clogged filter will cause stall, which will again give you very low fuel pressure as run out gas occurs.
I just posted mine with the exact same problem is a 1996 850 turbo. My mechanic change the plugs and test the pump is a 50psi he said is excellent. I drove it fron\m Oklahoma to Texas almost 300 miles no problem got gas drove it 12 mint and died again while driving stop started and it ok again. They told me to check the coli and replace it ($135) ouch!!! so I see on your post to check the fuel realy I think I will go that route
