Injector seals
Old Jan 2, 2012 | 01:25 AM
koko284's Avatar
Default Injector seals
Hello all,
Need help with injectors of my 1997 850 turbo. I read there are two o-rings, upper and lower. Where is the other one, is it side the rail?
Any idea where to find the yellow spacer near the tip of the injector. FCP carry the o-rings only. Please the pictures. Thanks.
Old Jan 2, 2012 | 09:57 AM
clean850R's Avatar
Pull the injector out of the rail to find the upper!
Old Jan 2, 2012 | 09:58 AM
clean850R's Avatar
Pull the injector out of the rail to find the upper! You'll have to get another injector for that end cap!
Old Jan 2, 2012 | 08:47 PM
koko284's Avatar
Appreciate your advice....is there another option than replacing the injector? like replacing the yellow seal only? I have three seals cracked out of five.
Old Jan 3, 2012 | 06:16 AM
clean850R's Avatar
Get an injector from the JY and see if they're broken! Have to be gentle they are fragile! Other than that????
Old Feb 29, 2012 | 09:44 PM
koko284's Avatar
Sorry for the late reply. I installed used injectors but didn't work, so I put the old ones back and are working fine so far. Didn't find the exact used replacement(Part # 0280155759) color red.
Old Mar 1, 2012 | 01:52 AM
058ovlov's Avatar
Old Mar 1, 2012 | 08:46 PM
koko284's Avatar
Thanks 058ovlov,
I was doing a PCV job and wanted to replace 2 injectors that were cracked near the tip, see picture. I put the old injectors back and they are working fine so far.
BlueVanACD2005
Engine & Internal
Apr 17, 2010 06:33 AM
holobox
Sep 3, 2009 07:12 AM
bullit850T
Jan 29, 2006 01:14 PM
elbert
Dec 6, 2005 01:18 AM
RLeighton
Jan 12, 2004 07:12 PM
