Interior Door Trim
Old Aug 23, 2008 | 06:20 PM
Old850's Avatar
Default Interior Door Trim
I'm planning to replace the interior cracked plastic door handle trim on the door panel. The part number is 9406220. I looked at the schematics at the dealership. It looks like I have to remove the whole door panel just so I can undo a single nut locking the door handle trim in place. Is this correct? Any suggestions as to how to glue these in? I assume they originally also glued these down because all the cracks are at the corners of the trim. I also assume that I will break a few things when I take the panel down. [:@]
Thanks.
Liz
Old Aug 23, 2008 | 06:26 PM
Default RE: Interior Door Trim
You have to remove the panel to get to them. There is 4 nuts holding the trim panel in. Thats why they crack like that there is a nut on each corner.
Old Aug 23, 2008 | 11:58 PM
Old850's Avatar
Thank you, Tech! What are the chances of me braking something else in the process?
Liz
Old Aug 24, 2008 | 07:54 AM
Not to great. They usually come apart pretty good. You have screws along the bottom of the panel and one plastic screw in the bottom front by the door hinge. Then remove the speaker grill and insert in the panel there is 2 t-30 screws and one long one in the speaker.I always forget exactly which one is the loing one but I think it is the left upper or lower. Then it should slide up and out.
hovonogila
May 16, 2019 02:28 AM
kevV50
Canada, Over Seas & Elsewhere
Apr 14, 2014 09:07 AM
netconcepts
Oct 29, 2007 09:57 AM
Volvoom
Oct 18, 2007 07:07 AM
01S60T5
Jul 3, 2007 10:20 PM
