keyless entry
Old Jan 13, 2012 | 07:12 AM
97black850's Avatar
Default keyless entry
Does anyone know where I can get an OEM key less entry remote, and also how difficult are they to program to a new vehicle?
Old Jan 13, 2012 | 08:44 AM
stage2c70's Avatar
fcp euro should have them , they cost 120$ . You will have to get the dealership to program it .
Old Jan 13, 2012 | 10:47 AM
I bought a pair off ebay but they aren't the OEM ones. Not sure who was the supplier to Volvo back in '95. The ones I bought for around 32 bucks have worked fine and I programmed them myself.
Do you have one that you can get the FCC number off of the back of it ??
Transmitter Replacement
If transmitter is replaced, unit may need reprogramming. It
is necessary that receiver be programmed with each key code. To
reprogram receiver, turn ignition switch to position I or II 5 times
within 10 seconds. Leave ignition on at fifth turn. Press either LOCK
or UNLOCK button on transmitter once within 30 seconds. If transmitter
is provided with different key codes, programming of each unique code
must be accomplished within 30 seconds. Turn ignition off. Verify
operation of each individual transmitter.
Getting the transmitter to link with the car can be a bit tricky and it took me quite a few tries to get it but it might just be me or the car.
Old Jan 14, 2012 | 08:12 AM
97black850's Avatar
alright, im gonna look into it, thanks
rickg
May 8, 2007 10:10 AM
sithhound
Dec 11, 2005 12:40 PM
JC
Nov 6, 2005 09:27 PM
dmoney
Jul 21, 2005 10:22 PM
rgarrett
Jun 16, 2005 03:08 PM
