lights in the climate control?
I have one light out in my climate control, that is assuming there are only 2 lights. do I have to remove the entire unit to change the lamps or can I just take off the face panel? What bulbs go in there?
3 Attachment(s)
You need to remove the whole unit. There are three bulbs in there. They are #74 bulbs, they are very small. They are available at Oreilly, Autozone, NAPA ... . Two on the right and one one the left. They are the black sockets with dual green wires leading to them.
You'll need to pull the radio out, if it's an original Volvo radio make sure you have the security code. Best to put on a glove when you reach in behind the climate control head but it just pushes out. |
Also note, that the removal procedure for ACC & MCC is different. For ACC, you take the radio out by pressing on the "tabs" on L&R sides of the radio.
I've never removed the MCC, so wait for other members to aid unless you already know how. JPN |
Originally Posted by JPN
(Post 336886)
it is very very very easy. replaced my bulbs last night. just remove the radio then push the climate control unit up-forward and it comes out then remove the three green cables connected to the unit.here is a write up for it
http://www.matthewsvolvosite.com/for...hp?f=1&t=19025 |
All sounds straight forward. Thanks all for the help.
Just in case some don't know, the light bulb number is the same for a replacement bulb be it a GE, Sylvania, Wagner or other brand. IMHO I'd stick with a name brand bulb and not something like an "Eiko" or some other no name brand. You may save a buck or two but you'll be in there replacing it a lot sooner. For the trouble some of these bulbs are to get at spend the extra dollar and get a better quality bulb. ;)
I seen that Kiss replied to this post so I didn't look at it until now. I'd like to add some safety information.
WARNING: As simple as this sounds, this job can actually send you to the hospital. If you have the ECC unit (temp knobs have numbers) you really do need to put some good leather gloves on. When you push the unit out from the back, it will pop fee, when it does your fingers or thumb will jerk into the SHARP plastic back there and it can give you a deep enough, nasty cut that may need stitches. I still have a scar from the cut I had. I didn't go to the ER, but maybe could have. ALSO: You need to have something to protect your arms from the unit flying out on to the inside of your forearms which can cut your arm. Crazy I know but it took a few layers skin off of my arm which was a surprise. I usually either make sure I have on thick sleeves or lay a hand towel over my arms before I pop that thing out. If you have the MCC unit (temp knobs have no numbers), it may have a few screws under the knobs that you have to remove and not take the entire unit out from the back. I found this out on a S70. |
Ya should know by now ya can't trust me. At least not at this time of year when I get all "nogged" up and am seeing double, safety goes right out the window !! :p
I didn't stress that "glove" enough or say why ... bad technician, bad !! |
(Post 337074)
1 Attachment(s)
Just pulled mine last night and upgraded to LED's. Slowly doing the interior lights one by one.
I used square ones and they just barely fit into the ECC openings. I went with the square ones thinking the light might spread out more. Not sure that's true but I like the result. The fourth one I'll pull apart and solder into the holder for the bulb illuminating the ash tray. They were only four bucks on ebay. |
(Post 337512)
These came from "rcttco"
eBay My World - rcttco My turn, tail and stop bulbs came from Autozone they were "Jam Straight". You can likely source them all at "superbrightleds.com" LED Lights for Cars | 12v | Super Bright LEDs |
