Lola's Progress Log
Old 03-18-2010, 02:11 PM
Legendsecko87's Avatar
Yeah, about that....
Women
  #402
Old 03-20-2010, 01:18 PM
Just ordered parts for rear brakes. They needed it... bad.
  #403
Old 03-26-2010, 12:11 AM
Just replaced all, well most, of my switch bulbs. They've been out for a long time...
  #404
Old 03-26-2010, 09:26 AM
_HighVoltage_'s Avatar
What are you changing on the rear brakes? Are you changing the parking brake mechanisms?
Did you change the bulbs on the shifter console? I want to change mine but it looks like a really tough job - removing most of the console...
  #405
Old 03-26-2010, 02:09 PM
The rear brake bads. They need them really bad. I'm under 2mm, so I flipped out on Monday really fast and ordered them from FCP that day. Parking brake stuff, nope. Although I should, my parking brake is really weak.
The bulbs on the shifter is fairly easy. I did a few of them with an LED swap about a year ago. The shifter is easy to get too. After you get your console out for the first time, it's a breeze. Don't freak out over it. A total of 8 or so torx screws and you're set.
  #406
Old 03-27-2010, 07:45 AM
Cool. I get it that you didn't turn the rotors, you just swapped the pads? How does that feel?
Also which pads did you get from FCP and are they squeaking? I have to change mine as well...one of the rears is toast, literally. I guess it has glazed, because it's still thick, it just doesn't brake at all.
  #407
Old 03-27-2010, 02:07 PM
Everything is coming in on Monday, so I'll know by then. I haven't really thought about turning the rotors. I just replaced the pads on my front ones a year or so ago, everything feels fine.
I ordered the Volvo OEM ones. I herd that OEM ones don't squeak if you put enough of the anti-sequel stuff on it.
  #408
Old 03-29-2010, 11:55 AM
Scary?
  #409
Old 03-29-2010, 12:26 PM
gilber33's Avatar
Is that your brake pad?
  #410
Old 03-29-2010, 12:39 PM
Yupp, rear brake pad.
  #411
Old 03-29-2010, 12:40 PM
gilber33's Avatar
LOL. Like living on the edge eh?
  #412
Old 03-29-2010, 01:33 PM
Actually no, I just forgot to look at them till last week.
  #413
Old 03-31-2010, 12:17 AM
Brakesone
PCVone
Running good after PCV: Incomplete
Spring Seat:Incomplete
Odometer gear:Incomplete
I have a major vacuum leak from my EGR gasket, so that's what's been causing a funny reading on my car. Going to get a new one!
  #414
Old 04-02-2010, 10:13 PM
Put the EGR gasket back on, but now it's running normal, but after a quick throttle blip at idle the car nearly dies. Any ideas?
  #415
Old 04-02-2010, 10:15 PM
I got the EGR gasket fixed. Everything is running well, unless I blip the throttle at idle the car nearly dies. Any ideas?
  #416
Old 04-03-2010, 10:46 PM
Fixed all of that, but I still have a vacuum leak somewhere. for doing the PCV, where would be a good place to look? I've checked all my IC hoses, EGR is on tight. Would a lower injector o-ring cause this? I normally idle at 20-22 in/hg but now I'm 18-20 in/hg
  #417
Old 04-06-2010, 07:00 PM
Spray around all the hoses and see if the idle changes.Use Brake Clean.
  #418
Old 04-07-2010, 12:28 AM
Done that, so I don't think it's any part of the hoses. I've done it to every part, done it to every connection, etc. Could it be a part in the manifold? Didn't do one of the support bolts on the manifold, would that be it? It's a pretty damn small leak though, but it's annoying.
  #419
Old 04-07-2010, 09:39 PM
It could be alot of things recheck everything really closely.
  #420
Old 04-07-2010, 11:02 PM
Okay, time to take the fuel rail off again :/.
Quick Reply: Lola's Progress Log
