loose wheel
;)my front wheel wobbles when i push at the twelve oclock position when wheel is in the air but not when on the ground i retorqued axle nut to spec is a little play in ball joint but the movement in wheel is dramatic is it the ball joint or maby the hub thanks
RE: loose wheel
[:@]sorry i got things bakk assword wheel wobbles whe on the ground is fine when jacked up
RE: loose wheel
I would think maybe balljoint but I would have to see to confirm 100%.
RE: loose wheel
I would suspect balljoint as well. If the wobble was side to side I would suspect the wheel bearing
RE: loose wheel
Check your control arm bushings. Mine had a bad one and allowed the wheel to move.
