loose wheel
Old Jul 28, 2008 | 03:46 PM
sheriffjohn's Avatar
Default loose wheel
my front wheel wobbles when i push at the twelve oclock position when wheel is in the air but not when on the ground i retorqued axle nut to spec is a little play in ball joint but the movement in wheel is dramatic is it the ball joint or maby the hub thanks
Old Jul 28, 2008 | 03:49 PM
Default RE: loose wheel
[:@]sorry i got things bakk assword wheel wobbles whe on the ground is fine when jacked up
Old Jul 30, 2008 | 07:02 PM
I would think maybe balljoint but I would have to see to confirm 100%.
Old Jul 31, 2008 | 08:43 AM
Psaboic's Avatar
I would suspect balljoint as well. If the wobble was side to side I would suspect the wheel bearing
Old Jul 31, 2008 | 09:28 PM
BriGuy's Avatar
Check your control arm bushings. Mine had a bad one and allowed the wheel to move.
sheriffjohn
Aug 1, 2008 08:25 PM
matrup1
May 7, 2008 06:25 AM
SMITTY70
Mar 22, 2008 04:16 PM
mafiosoroso
Oct 22, 2007 09:20 PM
Red XC
Aug 17, 2006 08:58 PM
