Low beam headlamp
Low beam headlamp
Hello Everyone!, this ismy 1st post here.
A couple of months ago I replaced the R.H. low beam headlamp bulb and noticed one burned connector on the socket. I bought a new replacement socket, cut the wires and replaced it, thought nothing of it until the light went out again! Once again the same problem - one of the socket female connectors where the bulb prong plugs into was discoloured "burned" to the point the plastic from the socket melted around the metal plug which would loosen up the connection causing the bulb to cut out. What am I dealing with here? I am at a loss where to go from here
Please help.
Please help.
RE: Low beam headlamp
Welcome to the forum, I hope you find it helpful & enjoyable.
I had replaced both R & L connectors with aftermarket, high-temp silicone type connectors ($10 or so for a set of 2). I bought them at AutoZone. It requires wire crimping or soldering, though.
Good luck,
JPN
Good luck,
JPN
ORIGINAL: tech
Maybe the connector didn't fit tight enough on the new connector when you installed it?
I would install another new one and make sure the connector fits really tight.
Volvo_Neps
1998-2000 model year V70
09-12-2024 06:53 AM
Volvoguy505
09-11-2010 05:53 PM
