Be a magician with your 850...
Be a magician and amaze your friends with your 850...
Trick Number 01
01) Lock all doors using either your power door lock switch on dashboard.
02) Unlock only the driver's side door manually, by pulling up on pin.
03) Attempt to open the fuel filler door -- It will NOT open.
04) Lock all doors using the key in the driver's side door.
05) Unlock only the driver's side door, by using the key only once.
06) Attempt to open the fuel filler door -- It will still NOT open.
07) Lock all doors using the remote keyless entry switch.
08) Unlock only the driver's side door, by pressing UNLOCK button only once.
09) Attempt to open the fuel filler door -- It sill still NOT open.
10) Lock all doors, using any method.
11) Unlock all doors, by using the power door lock switch on dashboard.
12) Attempt to open the fuel filler door -- It will finally open.
11) Unlock all doors, by using the key in driver's door twice.
13) Lock all doors, using any method.
14) Unlock all doors, by using the remote keyless entry by pressing UNLOCK twice.
15) Attempt to open the fuel filler door -- It will finally open.
Trick Number 02.
01) Lock all doors, using any method.
02) Unlock only the driver's door or all doors, using any method.
03) Wait 3 minutes, all doors will re-lock themselves automatically.
04) Lock all doors, using any method.
05) Unlock only the driver's door or all doors, using any method.
06) Open any of the door handles.
07) Wait 3 minutes, all doors remain unlocked.
Trick Number 03.
01) Make note that needle on fuel gauge is reading near empty.
02) Drive to nearest fuel station.
03) Pull next to fuel pump.
04) Leaving engine running.
05) Add fuel to fuel tank until full.
06) Pay attendant for fuel.
07) Drive away from fuel station.
08) Examine needle on fuel gauge -- it is still reading near empty.
09) Continue to drive home.
10) Examine needle on fuel gauge -- it is still reading near empty.
11) Turn off engine.
12) Turn ignition key to the ON position.
13) Examine needle on fuel gauge -- it has reset itself and is now reading full.
Trick Number 01
Trick Number 02.
Trick Number 03.
