Manual Swap pedal question
What is the easiest way to get the auto brake pedal assembly out? Ive undone the mounting bolts but cant figure out how to get it all the way out.
Unbolt the steering column...makes a huge difference.
Originally Posted by boxpin
(Post 372175)
which way is the spring supposed to go for the clutch pedal, coil to the front or rear?
also which shifter cable goes to which lever on the tranny? m56h
Side to side goes to the skinny arm. Gear to gear (1 to 2, 3 to 4) go to the bigger block.
I'll have to look again for the springs. |
(Post 372982)
I'll have to look again for the springs. Thanks |
