Master Key Will Not Open Wagon's Tire Compartment
Old Feb 2, 2015 | 06:05 PM
GregsAn850Guy's Avatar
Default Master Key Will Not Open Wagon's Tire Compartment
Hit very bad pothole resulting in deflated tire and probable rim damage on way home to SuperBowl Sunday kick-off in Canada's very cold north. Could not unlock sub-floor spare tire compartment. No phone, no spare, no time before kick-off. Result - took long slow drive on flat, shredding tire to oblivion, very reluctantly. No other keys (once home) open secret compartment. Do I add broken lock (definitely not frozen) to ravaged rim and retired rubber? Any suggestions? Thnx.
Old Feb 3, 2015 | 08:16 PM
try shooting some WD40 or similar into the lock. Possible some dirt or corrosion found its way in there in the past 20 years. Not sure why Volvo put a lock there in the first place...
Old Feb 4, 2015 | 07:24 AM
Thanks for a good suggestion, mt6127. So busy trying lock deicer given inhuman temps past few days, didn't even think of ol' reliable (WD40). Will try that once car back from tire dealer (towed there on flatbed). All this because muni failed road maintenance duties. Topic of news lately with many damaged vehicles from same potholes cause. Hmmm... time for tort.
Old Feb 6, 2015 | 08:24 AM
yep, that's why I keep a spare rim in the garage and run steelies in the winter! Its a good idea to also keep your tire pressure higher than the sticker - I typically run 36-39 PSI after having blown out 3 different tires all due to sidewall issues from hitting pot holes.
Old Feb 6, 2015 | 11:21 AM
cem308's Avatar
This is probably no help but mine will only open with one side of the key. My key wont work sometimes when I flip it over then it will open. I thought these keys didnt have a "side". Just thought Id throw this out there.
glm409
2001-2013 model year V70
Dec 22, 2014 08:55 AM
IC53
May 3, 2013 01:09 PM
elcs70
Mar 23, 2012 05:18 PM
pinhead
Nov 29, 2008 09:52 AM
